When I draw a dimension, the position of the measurement is random. Like if I click on point 1 and then 2 which might be 100mm apart on the sheet, the actual dimension line and text will appear like 300mm away from where I dropped point 1 and 2. Why? I am constantly having to adjust the position of dimensions because it's completely illogical. Why not allow us to place the dimension line, similar to how Revit does it i.e. you click point 1, then point 2 and then the 3rd click places the dimension line. This would simplify the use of the dimension tool.
