Pretty simple; if I make one view smaller than the other, I'd like the ability to set the match point betrween the two. It appears that by default it's to the left. Options could be left, center, right, top, and bottom. THANKS!
How do you sync views at different zooms? Assuming that is what you mean by "make smaller".
I though the Synchronize Views command always controls view zoom AND page/position on the sheets.
Hey Jes, thanks for the reply.
By "make smaller" I meant stretching one of the view windows to a smaller size. I think when there are comments and you cycle through them, the focus will be on that location in each view (even if only one of them has the comments). But when there are NO comments, and you zoom in and out (wheel), it seemed to lock to the left.
Ahhh. Makes sense. I just tried it and see exactly what you mean. Bluebeam def wants to use the left edge orientation on each window.
