I am startiing to learn, I have figured out how to scale for conduit runs. I would like to draw out feeder home runs in different colors. Also how to find boxes and other symbols to put in the toolbox
Hi Curtis, You can add multiple colors by drawing with the tool you already created, change the color, then add it to the tool chest again in that color. It will now be available for you next time. If you are looking for conduit runs in multiple colors that are already created or electrical tools to add to your tool chest, you can google "Bluebeam Electrical Tools" and there are a number of options available. Good Luck!
CAN YOU HELP ME TAKE A CONDUIT LENGTH OFF OF A DRAWING ELECTRONICALLY? bY CALIBRATING? iS THERE A VIDEO THAT SHOWS THIS CLEARLY WHERE i DO NOT NEED TO SPEND FIVE HOURS TO GET LENGTHS ? Sorry I forgot caps. I have a print that I need to get lengths of pipe, wire, etc, thank you
Why does this product (Revu 21.9.0 16288) take so long to startup after launching? I rarely need a Session, so if that's the problem (talking to HQ), can it be disabled by default? It's one of the slowest starting programs and takes so long to install updates. Am I alone on these slowdowns?
There was an error rendering this rich post.
Is there any consideration for Bluebeam to have a feature to reassign markups? I know it is simple to change the properties to a different markup but then you get into the game of changing the color and everything else. Wouldn't it be simplified if you could just reassign it to a takeoff, you've already utilized or…
Recently, I've been experiencing and issue in that when I use my hotkeys for the typewriter or text box, they don't work. I used to be able to then go click the icon on the bar and I'd then be able to drop a textbox or get the typewriter cursor to appear, but now that doesn't work either. I just tried uninstalling and…
I am not able to choose different colors for my layers when I am overlaying more than 8 layers together. All I am seeing is the graded color palatte in revu v21 rather than the default one where we can customize the colors based on the RGB values. Has anyone faced this issue before? Is there any workaround for this to…
How do I ensure my session allows for plan review markups? I cannot sort out how to enable one of my sessions to have both the review and plan review tab.
Small Biz and we have BB Revu 20 still in our conference rooms because it does not require sign-in. I tried putting Revu 21 in one conference room and had it signed in with it's own account, but then there were server side issues and then login was required again. Users were confused and entered their own login for…
Some of the BB marked up PDFs I receive have shading and "draw order" out of whack to the point that I cannot read what's below the block. All of the items should come in like the "12' APPLES" unit, in orange. Any thoughts? The preferred "Order" would be with the shading at the base level and the pasted fixture block above.
we have installed the software and tried to login with "name_example.com" Account using "Bluebeam Australia Region"., But it is not allowing to login. Showing the error like below snip. But., we tried to login with "Bluebeam United States Region" and it allowed login, but the Plan is showing as "unassigned" like below…
Hello!! I have been using Bluebeam for a decent while, and anything I have trouble with I can usually sort out on my own, but I am stumped. We have a set of plans, all of which are images with a peach-coloured background. To save on ink, I need to change them to grayscale, ideally. Please see the attached screenshot. It…
