I have several symbols that I've created for use in a Tool Chest. Is it possible to give the symbols a drop down selection box which I can define?
i.e. Having a drop down menu to select if the symbol is a recessed device or a surface fix device.
Hi Stuart,
Would you like the drop down selection box visible in the markup on the page? If so, I can't think of a way to do this. Maybe you could add a text box to a Grouped markup with the symbol and type in the text box, so not ideal.
Otherwise, you can create a custom Choice column in the Markups List. This will give you a drop down list of custom information that you can assign to markups. This information will only be visible in the Markups List and not on the markup on the page (unless the markup is a measurement in Revu 21).
Maybe TMI… You can assign the custom column properties to the tool saved in the Tool Chest. Please note that if you want to use that custom column info when using that tool in other PDFs, you would need to import the custom column into those PDFs.
Cheers!
Previous to recent versions of revu, holding the control key while starting a measurement/markup or anything that would trigger object snap would temporarily disabled it. This is extremely useful when you generally want object snap on but not right at that second, usually because of a dense area where there are so many…
Is there currently an option to enable a new tab opening when clicking on a detail hyperlink? This would be great! Currently I just split the view and then click the link, but this seems more straightforward for new users.
I was tasked with creating custom symbols for my company and I' having some odd issues. After importing the toolboxes, some of the symbols are "missing" in the sense that they don't show up in the toolbox. If I hover over the location where it should be, all the pop-up info still shows. I can select the symbol and place it…
How do i change the icons when i select count measurement checked after completing visual search? it only has the default icons and not option to add from my toolbox.
Before BB Revue was reinstalled on my machine, I used to be able to do a command to super easily change the properties of the fill. Now I have to go into properties, or use the fill color icon on the Appearance toolbar. I have lost that command and don't know how to get it back.
Before BB Revue was reinstalled on my machine, I used to be able to fix text to the text box. I have lost that command and don't know how to get it back.
It seems like every other day, Bluebeam requires me to sign in. AutoDesk doesnt. 365 doesnt. Please, please, please, have it stop. I use bluebeam on one machine, and it should know by its IP address and that its not be used fraudulently. Fix this!
Is the create legend option only available in the Core and Complete subscriptions? If so, how do i go about upgrading my current basic subscription to the Core subscription without having to purchase a new one? I don't see and upgrade option under my account information. Thank you
Hi. I'm always looking for ways to maximize my file viewing space and for the life of me I am unable to find a way to remove/hide/relocate the "file name" and its lengthy blank horizontal space from my setup. Below is a screen shot of what I am talking about: I'd appreciate if anyone knows how this area can be removed or…
I have most of my tools set up exactly how I want them and saved. However, every once in a while a tool will go missing or will be moved into another tool set. This might be user error, but I think a way to "lock" tool sets to prevent moving/deleting tools would be helpful!
