Is there any way for that
Can you clarify what you mean by drawing file?
I'm picturing a CAD file but maybe you want an editable pdf (vector file). I don't have answers for either format but understanding your needs helps others who may have an answer.
i want to convert it to cad file
Yes.
I use AutoCAD, so peruse your options… choose ones (check boxes) like turning patterns or filled regions into HATCH, inferring linetypes, and joining lines and arcs at intersections.
Play with it to make sure you get a clean CAD file in the end.
Yo @medhesh_008 Did this work for you?
Hello, I have used the Grab feature for years and it is one of my most frequently used tools. Recently, however, when I grab from one drawing and paste into another, the file size increases from around 1 MB to 2 GB. If I switch off “Take Vector Snapshots”, it resolves the file size issue and the drawing size hardly…
As part of preliminary estimating for roadway projects I have created a custom toolbox for area, length and count items. I can change the color. Is there a way to change the icon to something like SW for sidewalk area? I have the measuring tools set up with custom labels and layers to facilitate review and quantity total…
Hello, Can I import Chets Tool Items from Excel. I've a list of items in Excel (number, description, m, m2, m3 of Pc) I've to measure. Can I import it to Tool Chest. Thanks.
Good afternoon, I want to create a Tool-Chest component in "Tool Chest" that automatically numbers, e.g., W001, W002, W003, W004, ... and measures the area. It should place this on the plan-view with number W001 and the area. And then also place this number W001 in the Marksup list so that the link between a specific wall…
Hello! Today when uploading a capture from a screenshot, the image sets at 3D, does anyone know how to make the capture images to set at 2D? Thanks in advance
Hi All, I want to send selected sheets from my drawing Set to a sub contractor. Is there a way to send just the sheets I select from the Sets window? Thanks Ahead, Ian
