Is there any official marketplace (just like Google Play for Android apps etc) that BB supports certified plugin(s)/extensions development for rest of the world to buy and sell?
Hi @Raja Nagendra Kumar!
I don't know that this will be the answer you were looking for, but Bluebeam is pretty selective with what it considers as approved plugins/extensions.
You can view the app directory here:
https://www.bluebeam.com/app-directory/
As far as plugins, you can view the requirements for each plugin and how to activate them in the following links:
https://support.bluebeam.com/en-us/revu/resources/compatibility-system-requirements-21.html
https://support.bluebeam.com/en-us/revu/how-to/enable-bluebeam-plugins.html
I hope this helps. There's a few minutes worth of reading to do here, but I think it paints a pretty clear picture of what Bluebeam approves as plugins/extensions. Everything else is gonna be at your own risk as far as I can tell.
Edit 1: One of the links was not working correctly. Seems good now.
Hello! 2-part question: 1. Is there a method, after marking up plans, that I can Batch Change my scaled Dimensions from Ft-IN to IN? As I export to a workbook,I need to convert dimensions for formula use 2. Is there a better formatting or setup for markups, knowing that I will be exporting the data for take-offs? Thank you
Is there a way to take a markup and group it with a hyperlink and save it to the toolchest? I use the same graphic and hyperlink many times within a drawing set. Right now, I have been creating a new hyperlink pointing to a URL everytime. It would be a lot more efficient if I could create a markup that was grouped with…
