Checking the box [Do not show this message again] results in Bluebeam Revu 'changing' files even though the user only intended to view the contents and has not made an actual edit.
A prompt to save/not save then appears when the user closes the file.
Would it be possible to have Revu remove the 'Untitled' viewports only if/when the user chooses to use a calibration/measurement tool?
This would help make Revu a more useful default PDF handler for people who need to open/scan through a lot of PDF documents without making measurements in each of them.
Thanks.
TH
