I have a black PDF piping diagram and want to colour all the different types of pipes. Eg potable water = Blue, RO water = red, Sewer = green. How do I do this please.
I think I need some more information to answer that. can you provide a screen shot?
@Deano, If I understand correctly, it seems like you have a drawing with the piping diagrams already laid out, in black. What you are looking to do is change the colors of some lines to reflect your schedule.
The easiest way is to simply draw over those lines using the polyline tool, with the correct color. See sample below.
If you want to get fancier, you can also use "line styles" to include text on the line.
That's just what I wanted Shaya. I have only just downloaded the program so now I need to find the polyline tool and have a play.
@Deano, WELCOME!
This may help you find the polyline tool…
Pro Tip: Check out Bluebeam University - So much to learn there:
https://university.bluebeam.com/
Much luck!
Legend thanks.
