My "Dynamic Fill" says it's disabled. How do I enable it?
Hi @DSHUFF!
Can you check your Revu plan? Dynamic Fill is a Complete plan feature.
To check your plan, click on your email/BBID in the upper right hand corner.
Hi everyone! What is the experience with Revu on Mac via Parallels? I have been exclusively using in the past decade Revu on several iPads for marking off, measuring, take offs on the go but now as the iPad app gone and the new Cloud / Mobile replacement is still in the cooking I am forced to seek alternatives. As I have…
Can Bluebeam convert a .pptx file to a PDF, and if so, how?
How do I show a file path in a text box?
Hi, brand new user here. Just sat through several hours of tutorials, and I'm trying to determine how useful Bluebeam will be for tracking my daily as-builts on a road project. I'm one of the first inspectors using Bluebeam here. The problem I am having is using the Polyline Sketch-to-Scale. I cannot seem to edit a drawn…
知っている方が居たら教えていただきたいのですが、図面を翻訳する機能はありますでしょうか? よろしくお願いします。
I am trying to delete a previous session and entering a new one. I keep getting an internal server error. Does anyone know who to get a hold of to fix this?
i cannot see my properties panel. it only shows up if i change profiles. i cannot use shortcut key Alt-P to make it visible
When I am trying to search for keywords on a plan/document, it displays 0 results found. This is the first time I've had this problem. Does anyone know why that would be?
We are currently reviewing our licenses and find that we lack the necessary functionality to scale up or even maintain our current number of licenses. We would like to see functionality for creating and managing templates for control plans, commissioning protocols, checklists, and similar field documentation, with results…
I hope that is what the feature is called that I am referencing. I have used Blue Beam now for a couple years. I have always used the Line and Polyline tools when drawing things, especially overlays to buildings where I want to keep nice straight lines. In the past, I could select the tool, let's use Polyline: if I held…
