Does anyone know if there is a way to create a line or measurement markup that automatically segments a line into predetermined length segment?
For example…Drawing one line across a page with an indicator mark shown at every 10 foot segment.
This is an interesting concept. I just dabbled into it for a few minutes, one solution is to create a Custum Line Style. it is NOT PERFECT and a perhaps a better solution can be out there.
Basically I created a line style with a Dash, text and dash.
2. Create a new line style. With a Dash, Text, and Dash. (The Text I used was ')
3. Change width of each dash to 21.6
Important! Do not click on Scale with line thickness!
Result:
Note, it will also vary with the drawing scale. I created this on a drawing that was scaled 1/16" - 1'.
Hope this helps!
