Hello everyone, do any of you use a graphics tablet with a pencil for input? We use Bluebeam for quantity takeoff and draw markups all day.
Thank you
Hi BAPPERTM
Happy to help. Unfortunately, Graphics drawing tablets are untested with Revu therefore, we can't guarantee that they will work. For most drawing tablets, all you need to do is install the driver, and Revu will recognize it. However, since we have not tested this, we cannot confirm they will work.
So sorry if this was not the answer you were looking for. If you have any other queries, please do let me know.
Many thanks, Hercia
