I have some partition drawings in PDF I would like converted to objects I can edit in BB Revu.
Hi @Ben Rabb - what are you looking to edit?
After unflattening the PDF, the markups (callout, dimension, rectangle, snapshot, and text box) can be accessed and edited.
@Ryan Arbuckle
callouts, partition materials, etc. After unflattening I still cannot select the callouts
It sounds almost like you are looking for a similar ability to modify a .dwg file in something like Affinity Designer / Adobe Illustrator but for a PDf in Bluebeam. Is that about right?
