When in the field with my iPad it makes duplicate copies and saves the data I input on the duplicate instead of the original. I then have to delete the original and rename the duplicate when I get back to my desk. How do I stop that from happening?
Hi Tara! I'm sorry that's happening to your files. Here are some steps that you can try:
Clear the Studio Project cache
1. Close Revu.
2. Open the Windows Start menu.
3. Type "%LocalAppData%" (without the quotes).
4. Press Enter.
5. From the AppData\Local folder, open the Revu folder.
6. Go into the folder called data.
7. Then open the folder called studio.bluebeam.com.
8. In this folder look for the folder labeled with the 9-digit Project ID Number and rename it.
9. Add "_old" (without the quotes) at the end of the folder name.
10. Reopen Revu and go into the Project. See if it is working correctly now.
