How do I import my Notary Seal and add it to my stamps? I scanned the seal and uploaded it to Blue Beam using the create stamp tool. When I use it, it stamps a whole 8.5" x 11" page. I just want the seal.
When you create the stamp, are you setting the size?
https://support.bluebeam.com/online-help/revu20/Content/RevuHelp/Menus/Tools/Stamp/Editing-Stamps--MT.htm
Yes, but that just creates a generic stamp. I need to import a custom stamp.
