Please improve the Rotate function when rotating with the grip on plan. It has like a 15° resolution. Please make it more granular / smoother.
Hello,
If I understand your question correctly, you want to make a rotation at 15 degrees? This is possible if you hold down the shift key. Then any desired degrees can be determined. Without a shift key it is at 0, 45, 90 and so on.
Is this what you mean?
I think the question is the opposite - being able to rotate to any degree without it feeling like it "clicks" or "locks" at certain intervals.
If you hold down shift, you can rotate freely to much more granular angles
With me it is the other way around. the standard is free rotate and if i want to draw in 45 or 90 angles i have to use the shift key.However i dont know how to undo this option. I use mostly 45 and 90 degree angles. Is this an option in the menu perhaps?
