As an electrical contractor are there any significant changes that should persuade me to update from 2016 (paid in full) to the current version (annual subscription) software?
That's a good question. I'd be curious just to see when tools and features were introduced from a historical point of view.
I have my toolbox with the tools/symbols I've imported and made over the years.
The gear on the left side of the screen toolbar use to have all of my edit tools (color, font, line size, etc.…) Now it is just file attachments and file properties and the edit tool are across the top toolbar. What did I do to change it and how to I fix it?
What is the schedule for enabling Cloud to allow batch stamping and signing of pdfs along with digital signatures as is available in Revu on Windows? It would be most helpful to be able to access, stamp, and sign drawings on an ipad instead of carrying laptops.
Hello everyone, i was new to bluebeam. And i found it very depressing that everytime i calibrate my scale, it was 0.093138cm=112.5mm and everytime i apply this scale. the scale turns into 9.313.815cm=11.250mm. can anyone help me with this. Thanks in advance.
I used to use the "paint can" fill option all the time when organizing my PDF's, and that icon disappeared a couple years ago. Did it get changed or modified? Is there an alternative that will do a similar task?
Is this a way to not have leaders attach to the top and bottom items like text, only to the left and right sides?
I would like to know how to incorporate new drawings and have all the previous mark ups imported onto those drawings easily so that i can keep the take offs up to date on the most recent drawings
About 4/5ths of the way through the 21.8 MSI installation, a Custom Action named Call_LaunchShellExplorer is trying to open a .bat in such a way that Windows is prompting the user to select which program to use to open it. For now, we have simply added a transform to prevent that CA from executing. Has anyone else seen…
Recently, when drawing lines, polylines, the linework on screen is extremely thick. Does not match the default line thickness, just really thick, rasterized lines. Then when the command/lines is finished, the line changes down to the correct line width. Is there a setting to fix this glitch?
Hello all, I've been searching around trying to figure out if this was possible but have had no success. I'm wondering if it's possible to take 2 or more exhibits and combine them along the matchlines 'WITHOUT' snapshot. Snapshot essentially turns it into an image. My intent is to retain the attributes of the original .pdf…
this change from Bluebeam for iPad to Bluebeam cloud just made the program useless. When we are in the field, attaching a photo to a markup was 80% of the point, so when exporting a summary, the photo would be with the callout. How is this most-used feature gone? I am just now finding this out at 1am and have to travel in…
