When you measure length in bluebeam and have to manually edit the numbers, it would be nice if the new length had the same starting point as what you originally drew. Thanks!
Do you have an example of what you are trying to do?
Sure, let me explain. Take any measurement from the left to the right. Now edit the number to resize it. The program will keep the point you started at on the left, and change the point it ends on the right. That's perfect!
However, now take a measurement from the right to the left. Edit the number to resize it. It'll keep the left point and change the right point, losing the point of origin.
I would love for bluebeam to simply keep the point of origin of a measurement after an edit, no matter which direction the measurement goes.
