Is there a way of deleting a scale from a page (i.e. have a 'Set Scale' option to 'Scale Not Set')?
Not that I have found - I wouldn't mind one either - I made the mistake of adding a scale of my cover sheet, and it's an isometric view 😜
I think the best you can do for now is set the scale as 1:1
There is a way if you don't have any markups on the PDF and just want to remove the scale. Go to File > Create > From File. The only caveat, is that if you have any markups, you need to export them first - otherwise, they will become part of the PDF content.
Hello! 2-part question: 1. Is there a method, after marking up plans, that I can Batch Change my scaled Dimensions from Ft-IN to IN? As I export to a workbook,I need to convert dimensions for formula use 2. Is there a better formatting or setup for markups, knowing that I will be exporting the data for take-offs? Thank you
Is there a way to take a markup and group it with a hyperlink and save it to the toolchest? I use the same graphic and hyperlink many times within a drawing set. Right now, I have been creating a new hyperlink pointing to a URL everytime. It would be a lot more efficient if I could create a markup that was grouped with…
