When rotating a mark-up, it only let's you rotate every 15 deg. can this be changed to rotating every degree?
Holding down SHIFT will allow you to rotate a markup by a single degree. It might also be helpful exploring the Properties Panel. Under Layout, you can manually change or input Rotation.
I am trying to get or develop a way how I could get an automatic distance between two devices taking into account some parameters that I define
If I measure some items several times, and then an hour later find some more to measure, can I reuse the markups I used initially without adding to the Toolbox? I see there is a format painter but this just changes the markup appearance without changing the markup properties such as layer, description, etc. If I added…
I'm using the mobile app for iPhone and my project recently stopped updating all the changes I make on my laptop. I'm currently running back and forth taking pictures of different details and going back to the building to layout work for my guys. Is anyone else experiencing this issue? I hope it's something really dumb…
I am open to purchasing a higher license, but first I want to see if this will work like I am hoping it will. My company adds user data in a spreadsheet (e.g. IP Addresses, SN, etc), and we would like that info to go directly into our as built drawings. The idea being that we would only have to update the information in…
I am looking for a way to organize my existing layers on a project that I am working on. I have yet to find a way to move the layer to a sub group. In this example I would like to move all my overlays to one group (Overlays would then contain Power, HVAC & Roof).
I seem to have quite a few tools that are not accessible. How do i activate them?
I drew two lines and want to measure a distance from the intersection of the two lines to another point, however, I cannot seem to find where the snap controls have been moved to in BlueBeam Revu 21.8. For reference I have snap to content and snap to markups both enabled.
What are these numbers used for starting from 1 to how many mark-up tools you have, as per below 1-8? it's not on any other mark-up tool in my Tool Chest
Am I missing something? I was previously using revu ipad in the field for viewing drawings and scaling plans. I have recently updated to a bluebeam subscription and downloaded the new app on the ipad, I have not been able to figure out how to scale on the ipad. I have been able to do this on the web app on my computer but…
Hi All, When I Slip Sheet in Revisions from the Batch menu I already have to manually match my files due to filenames issues. The frustrating part for me is that I also have to manually add the Set Tags because of drawing format. Is there a way to have BB autofill the tags from the Current Matched pages to the Revised…
