Is there a way to delete all layers from all pages of a multi-page document in a single action? I can only see how to do it one page at a time.
@Ross I have found that if you combine files, it can remove all layers in the new file. The following steps may help save some time.
4. Make sure that merge layers is not checked.
5. Select add open files and ok.
6. Delete the blank page from the new combined file and save it.
The new file will have no layers, and you can use the same blank document over and over for this purpose.
This depends on how the layers were created. If you have combined a file made up of pages that already had layers on them and transferred those layers into the combined file, they will be grayed out on the layers panel when you aren't on the same page/pages they transferred over with.
If, however, you created the layers on an already-multipage document, those layers should already work globally. So, if you delete one layer, it would delete from all pages it was on. Additionally, if you wanted to grab all the pages at once, you should be able to use Shift or CTRL to highlight multiple layers at once and then choose to delete. This would theoretically delete those selected layers from all pages in one swoop (especially if you checked all the boxes from the pop-up that appears when deleting layers.
Ashley, thanks, this is somewhat helpful, but not exactly what I was hoping for.
I get pdf files of multiple sheets from people who printed them out of e.g. Autodesk applications. It's very common in our office, and I also get from external Project consultants. But I'm often the one who has to manage & collate different pdf files, most of them having layers, and before submittals — delete the layers because permitting agencies reviewers don't work with files having layers.
So, rather than trying to coach & educate multiple people contributing to the project about the way they print from their various Autodesk applications, it'd be just easier if I could easily delete all layers from any multipage document, in one stroke.
For instance, here's the layers in one sheet of a 45 sheet set…
And here's the layers in another sheet of the same set..
(there's still more than shown). That's the same person printing — she's printing the same way. It's just evident that that the Autodesk files are "accumulating more "stuff" all the time, and that stuff leads to more layers.
So I think you see from the above my problem is that in a document with say 10 or 50 pages, with layering like this, the layers seem infinite, & being able to delete one specific layer from all sheets at one time, isn't quite working for me. I guess my term "globally" that I used initially might not have been the right terminology.
Again, rather trying to control the way that various people print to pdf's, it'd be easier if I could easily delete all layers in one go.
Thanks
Thanks Glynis D.! Good & easy work around.
I am trying to get or develop a way how I could get an automatic distance between two devices taking into account some parameters that I define
If I measure some items several times, and then an hour later find some more to measure, can I reuse the markups I used initially without adding to the Toolbox? I see there is a format painter but this just changes the markup appearance without changing the markup properties such as layer, description, etc. If I added…
I'm using the mobile app for iPhone and my project recently stopped updating all the changes I make on my laptop. I'm currently running back and forth taking pictures of different details and going back to the building to layout work for my guys. Is anyone else experiencing this issue? I hope it's something really dumb…
I am open to purchasing a higher license, but first I want to see if this will work like I am hoping it will. My company adds user data in a spreadsheet (e.g. IP Addresses, SN, etc), and we would like that info to go directly into our as built drawings. The idea being that we would only have to update the information in…
I am looking for a way to organize my existing layers on a project that I am working on. I have yet to find a way to move the layer to a sub group. In this example I would like to move all my overlays to one group (Overlays would then contain Power, HVAC & Roof).
I seem to have quite a few tools that are not accessible. How do i activate them?
I drew two lines and want to measure a distance from the intersection of the two lines to another point, however, I cannot seem to find where the snap controls have been moved to in BlueBeam Revu 21.8. For reference I have snap to content and snap to markups both enabled.
What are these numbers used for starting from 1 to how many mark-up tools you have, as per below 1-8? it's not on any other mark-up tool in my Tool Chest
Am I missing something? I was previously using revu ipad in the field for viewing drawings and scaling plans. I have recently updated to a bluebeam subscription and downloaded the new app on the ipad, I have not been able to figure out how to scale on the ipad. I have been able to do this on the web app on my computer but…
Hi All, When I Slip Sheet in Revisions from the Batch menu I already have to manually match my files due to filenames issues. The frustrating part for me is that I also have to manually add the Set Tags because of drawing format. Is there a way to have BB autofill the tags from the Current Matched pages to the Revised…
