It would be very helpful if Bluebeam would allow a default setting, or remember the last setting used, when using the measurement tool. As of now, when I calibrate, I have to also select the precision to 1/16" instead of the default 1/4".
same here.
I want to change this default value to 0 instead 0,01 (metric system). It irritates me to have to adjust this every time
Yes, I need to change the default precision from 1/4" to 1"….this wastes so much time and the extra fractions clutter up the take off…. for what we are measuring, 1" precision is all we need… Is there a solution to this challenge?
I've seen this suggested more than a year ago (when I suggested it myself, at some point). Can we please have this feature soon?
Agreed! I've spent 10+ years changing the Calibrate - Precision from 1/4" to 1/16", so much wasted time for what is probably a quick fix! If we can get a "Set as Default" for the precision field in the Calibrate tool that would be such a big help!
