I see this number for one of the sessions but not sure what it is indicating.
That is the number of unread markup alert notifications.
https://support.bluebeam.com/online-help/revu21/Content/RevuHelp/Menus/Window/Panels/Studio/Studio-How-To--MV.htm#Alert_Other_Session_Attendees_to_a_Markup
Will it be possible that this notification number alert be on the "Notifications" tab as well after the user click on the session? For most new users can't easily find where the notifications are after they got into the session.
Recently, when drawing lines, polylines, the linework on screen is extremely thick. Does not match the default line thickness, just really thick, rasterized lines. Then when the command/lines is finished, the line changes down to the correct line width. Is there a setting to fix this glitch?
Hello all, I've been searching around trying to figure out if this was possible but have had no success. I'm wondering if it's possible to take 2 or more exhibits and combine them along the matchlines 'WITHOUT' snapshot. Snapshot essentially turns it into an image. My intent is to retain the attributes of the original .pdf…
this change from Bluebeam for iPad to Bluebeam cloud just made the program useless. When we are in the field, attaching a photo to a markup was 80% of the point, so when exporting a summary, the photo would be with the callout. How is this most-used feature gone? I am just now finding this out at 1am and have to travel in…
I have installed Bluebeam on a new laptop. Trying to read pdf files is not happening. Thumbnails show up but main window is either gibberish or blank. Have shutdown and then restarted and deinstalled and reinstalled to no effect. Repeated attempts to access Bluebeam result in laptop freezing and need to hard shutdown to…
Hi all, I have many tools showing as disabled & can't do my take offs. This includeds my tools in my tool chests. Any suggestions before I cry?
The rectangle function will allow a colored fill to be used, as will the ellipse function. Is there a way to "fill" an area that is defined by a polyline?
I've created a dynamic fill of an area on a PDF, and am unable to delete it; even using the Dynamic Fill option to "Clear All", "Clear Fill". How can I delete/erase this dynamic fill?
When I add digital signatures, the window doesn't close after I'm done. It doesn't freeze. I cannot change locations on the document. It will stay open and let me repeat the exact process but never closes. I have to go to Task Manager and close Revu. Any thoughts? Thanks,
I recently upgraded my bluebeam from Core to complete. now my interface is on view mode, i have tried to comeback to markup mode but can not fine the markup mode please i need assistance.
After the recent update, my search function does not work any more. I have tried my files including the ones I have successfully searched words in before the update. Is this a bug? How can it be fixed?
