I am an electrical engineer creating electrical plan drawings for buildings. If I am creating a lighting plan, my first task is to locate the lights on the plan. My next task is to connect the lights together in strings and designate how power is provided. The strings are easily created by using a polyline that touches on each light. This leaves straight line segments between the light fixtures. Convention has it that all of these line segments be arcs. To convert the straight segments to arcs, I need to select each segment then right click and convert to arc then tweak the arc shape. I was hoping there would be a faster way. Perhaps a poly line arc? Or select each segment and press a short cut key (ctrl+a)? I am just trying to make the process easier and with fewer steps.
