Architectural details are drawn at 3" per foot and we have full sheets of details at this size. Please add this scale into your standard scales. 6" per foot is also used for some details. Since these scales are not available we always have to set the scale of the sheet manually. Please add these common scales to your standards.
Hi challing, thanks for the feedback. We don't have near-term plans for updating the out-of-the-box list of architectural scales used when setting a scale on a drawing or viewport. When working on these sheets, do you find there is an existing dimension that you can use for "calibrating" the drawing? If so, is this a viable workaround for the time being?
It is worth noting you can add your own scales to the list in Revu 20 or 21. When adding a custom scale, like 3"=1 ft, you can select to +Add Preset button and it will add it to your list of preset scales going forward. Does this accomplish what you're looking for as well?
This discussion has been moved from Product Ideas to the Tips & Tricks topic to gain more comments and visibility.
