VOTE: Which of these BATCH features has helped you out/been the most beneficial to you?
The Batch Menu provides easy access to a handful of tools that can be used on multiple PDFs at the same time. If you've used any of the batch features and functionality, we're certain you have a favorite. Vote on yours below!
Batch functionality is available in Core & Complete plans.
VOTE: Which of these BATCH features has helped you out/been the most beneficial to you? 17 votes
Comments
Batch Compare Documents
Hi!
I would really like some information about how the "Match Filter" feature can be used. Select Advanced in in the Batch Compare Documents dialogue to see this feature. Unfortunately, the manual does not specify how to use this feature. The manual specifies the character wildcards, but not what the meaning of the filter is. Does it match the part of filename to be ignored? Or the part of the filename to use? Or something else?
Can you point me in the right direction?
regards Jon Brewer
1 -
Jon, the "Match Filter" is where you would use those Wildcards. For example, if you select the Match by: File Name, Page Index, the Match Field is by File Name and if you are using file names that are not as common or slightly unorthodox, the wildcards can be entered into the "Match Filter" to allow Revu to locate the correct documents and compare them correctly. (Example: A1.1,1-First Floor Plan South can be located by matching A1.1.1*)
If you change that to Match By Page Label, than the Match Field will reflect Page Label and the Match Filter can be used to compare items by those page labels.
I hope this helps clarify that, but feel free to reach out in the Community Chat if you still have questions. Thanks!
2 -
@Jon Brewer check out @Scott Koenig's recommendation. We hope that helps!
0 -
Hi!
Thanks Angela and Scott!
What filter should I use to match these files correctly?
file1 = "CP-004043-Prel - BOM.pdf"
file2 = "CP-002066-Prel - BOM.pdf"
Is it even possible? All the examples I have seen are examples where the filenames have a common prefix, but differ at the end of the file name. In my case, the files I need to match, differ at the beginning of the file name.
(I have posted the same question in the community but have not got an answer yet.)
regards Jon Brewer
1 -
Hey Jon, those files would be difficult to match even with the wildcards. Is there anything in that file name; a number, the "Prel," which would trigger in your company that these files should be matched? For example, if the file ends in the Prel and that tells you that it should be matched with the other Prel file you currently have? If that is true, you could use the "*" wildcard prior to Prel and it should find and match those. (*Prel* or *Prel - BOM)
1 -
@Jon Brewer - we have another question for you!
Helpful tip so we don't miss your comment! When you respond, please tag @Scott Koenig and me :) We'll be alerted that you've replied. Hope this helps!
0 -
Other!
Batch Print for me.
1
Categories
- All Categories
- Certifications Overview ↗
- BCP User Group
- BCI User Group
- Welcome Guide
- Join the Discussion
- 3.7K Discussion Topics
- 440 Peer Support
- 704 Product Ideas & Feedback
- 2.5K Community Hub
- 12 What's New?
- Release Notes Website ↗
- Built Blog ↗
- Product Support
- 69 Bluebeam User Groups
- User Groups by Location
- United States
- Canada
- Europe
- Asia Pacific
- User Groups by Interest
- Architecture & Design
- Construction
- Engineering
- Subcontractors & Trades
- Academic Educators
- Government
- Product Ideas & Feedback
