Importing Bookmarks from Existing to New PDFs
Hello,
I've been searching for a way to import existing bookmarks to a new pdf using bluebeam, but there is no such function. I reached out to Bluebeam support and they confirmed that this function does not exist and I should make a suggestion here.
I would like to see a bookmark import function. Coming from using PDF Xchange Editor, you can simply copy the bookmarks in the bookmark window and paste it to a new pdf's bookmark window. I switched jobs recently and my current company only use Bluebeam.
Please let me know if this is in the works.
Thank you.
7
7 votes
Active · Last Updated
Comments
  • I can see the benefit of this but in the meantime, is there something special about your bookmarks that recreating them automatically wouldn't solve?
    https://www.youtube.com/watch?v=acEmk19u2AE
  • MPham
    MPham Posts: 3
    My bookmarks are not special, just need to jump to the correct page. Bluebeam auto bookmark function works well for drawings, but doesn't work for reports where you cannot easily assign bookmarks.
    What I do is I would have individual pdfs for each section of the report, then for each new revisions, I would combine all the pdfs and redo all the bookmarks each time.
  • When we work with specifications, having similar formatting issues to your reports, that limit the PAGE REGION automation that Bluebeam has built in, we solved the problem with careful standardization of headers and footers that allow the PAGE REGION to be used as easily on all copy documents as it does on drawings.
    ~j
  • MPham
    MPham Posts: 3
    Thanks Jes, that is a good way to do it. Depending on the requirements of a particular document format, headers/footers are not always permitted.
    I just Hope Bluebeam will implement the copy and paste function for bookmarks, so if ever need to revise a pdf (replace, delete, or recompile), we wouldn't need to redo all the bookmarks.
  • I agree. Importing and exporting bookmarks would be extremely helpful.
