Re: Changing Multiple Text Box Shapes
I have never noticed this in the right-click menu and I have been in there a million times!
Re: Markups list - line length not showing up
@Matt Ruhrer, is correct. to calculate length, you must use either the Measurement Tool or the Polylength Tool.
Bluebeam Take Note: This situation highlights a strong case for Bluebeam to implement an item substitution feature. Currently, @Davide would need to redraw all these lines manually. Imagine the efficiency if Bluebeam allowed us to select existing lines and convert them directly into measurements. The time savings across all our workflows would be significant.
Re: Capture Photos from iPad Camera and attach to Callout or other Markups
Second this… I have been trying to retool the Architect Review items to work like this used to when I used iPad for punch lists… So far, very cumbersome and laden with work arounds, so - not much luck.
Davide,
The line doesn't have a length associated with it as it is for drawing. You need to use a measurement tool to get the length. You can create specific tools using the measurement tools also to customize the output.
Re: With Bluebeam do you have the ability share a document?
Studio Sessions is the way to go. Follow my How-To guide to get started.
As mentioned, the selector disappears with multiple markups. One thing you could try is to change one of the hexagons to the shape that you'd prefer. Then, right-click the new shape and choose Format Painter.
Your cursor will become a paintbrush. You will be able to click the remaining shapes and have them change.
Re: Revu 21 - Window preview pane to show location on page?
Dan,
Not sure if this is what you are wanting, but if you turn on the thumbnails it will show a small sample of the drawing with the area that is in the current view highlighted in the drawing.
I was going to say "Select them all in the markup list" but if you pick more than one, you can no longer change the shape. 🤔
Unfortunately, I tried all methods I know of to select multiple markups and once you select more than one, the shape selection option disappears. This would be a good suggestion for improvements to REVU.
Re: Who's joining me at UNBOUND September 30-October 2?!
YESS, @Doug McLean !!! Are we going to see a Doug fan club there?!
