Re: Can I auto update Bluebeam Markup List Exports for Excel
Not that I've been able to find.
Good to see that you're using Power Query though. It would be awesome if we could get a connector for the markup metadata and pull it direct within PQ w/o having to do the Markup export.
Re: BCP Update Coming: Exam Update Releasing June 3rd - Get ready for the latest changes!
So what you're saying is, we should take the exam before June 3rd? 😁
Re: How to Copy-Paste and Edit Text boxes with Formatting
OK, I misunderstood what you were trying to do. I thought the "text box" you referred to was made in BB Revu. But it's the one from the printed document, so what I was saying doesn't apply.
I made a couple of possible samples of something you can edit. I'm sure someone more experienced can make a better (cleaner) solution, but this is one way to solve your problem.
In a typical document, how many of these tables would you have to edit/modify?
Re: Make a way to move the detached markup list or pdf tab when it goes off screen
This happens to me from time to time. If you can drag any portion of the window and resize it manually, the top bar that allows you to move the window will pop down and give you full control of moving the PDF again. I'm not sure if this will work for you since you don't have any resize options.
Do you use multiple displays? If so, it could be an issue of the interaction there. I often have to disconnect my additional monitors and then do the software restart. It's NOT a good way to get the job done, but at least it allows me to move on with my day. Before I figured out that solution I would be dead in the water until I restarted my PC and get a fresh boot.
@Luke Shiras, I love the way you you did that. Looks real neat!
I think that this can also be resolved if we just had basic Microsoft Word Style Formatting in text boxes. It's an issue that has been brought up many times. Lets make in a priority!
