Re: Plan owner edit another contributor's redlines?
Yes, this can be done now but you need to establish the STATUS options you want before making the Studio Session. Follow this guide I made for more details…
Re: Can't access Revu
This may not be relevant but I looked for the login issue I previously had with using Revu 21 on Parallels on my Mac. I found the solution to be this: If you cannot log in to the 64 bit version, first log in to the 32 bit version. That's what a couple of people suggested and it worked for me. (In the 64 bit version, the login box was not functional).
I found the 32-bit version login on the Windows Start menu.
If this doesn't help, I hope someone else can help soon…
Re: Quantity link with duplicate column names?
Hi @fnava - Thank you for posting in Bluebeam Community!
You will need to make sure the custom column doesn't match any of the pre-existing columns below. If it does, you'll need to change the name of the custom column:
- Subject
- Page Label
- Page Index
- Lock
- Status
- Checkmark
- Author
- Date
- Creation Date
- Color
- X
- Y
- Document Width
- Document Height
- Comments
- Wall Area
- Length
- Area
- Volume
- Count
- Measurement
- Label
- Sequence
- Capture
- Depth
- Rise/Drop
- Slope
- Layer
- Legend
- Height
- Width
- Space
- 3D View
If this doesn't help please reach out to our technical team for further support, complete this form and they’ll be more than happy to assist you!
Re: Send a message to all attendees of an open session.
Can you use the "chat" box? On mine, it's at the bottom left corner of the screen when I have a session open.
Otherwise, you can right click on an attendee's name and select to send them an email. But it doesn't seem to allow you to select "all" or "multiple" attendees simultaneously. So, you'd have to send emails one by one, and I'm pretty sure that is not what you are wanting to do.
Also, it won't even let you do that individually with attendees that have not joined yet.
RickO
Re: Mirror PDF
Hello!
I followed your steps in the discription above and it works just fine. I would like to take it a step further though.
The reason I want to do this is to overlap to another pdf (drawing) to se if there is any differences between them. This does'nt work when my new mirrored pdf is blank when i go to Document> Overlap pages. (se attatchements)
Is there any way to fix this?
Also, just to be sure. Is "Flatten" the command with the weight? I have a Swedish version of BB Revu so I have a bit of language issuses.
Re: Selected tool will not release using escape key
You can find tech support in the app. Go to Help > Technical Support. Then you can search for your issue or go to the bottom of the page and select 'Submit a Ticket'.
I've always been pleased with Bluebeam's Support team. Maybe someone else will swoop in with an answer, but this is the best I an offer with my experience. lol
Re: Problem with creating formulas in v 21.4
Wanna make sure I understand. You made a formula-type custom column called "Qty". You want the expression to reference an existing column to get the quantity automatically added?
If so, here's how I think that would look:
Obviously, you can customize to your liking, but with this setup I clicked 'OK', and tested it out with no issues. Is this what you've done aleady?
Re: Takeoff Seaming diagram
Ah, 6'-7" wide roll. I was thinking sheets like plywood (my bad). If you just want a pattern, you can make your own. You can even import from AutoCAD.
