Re: Send a message to all attendees of an open session.
Can you use the "chat" box? On mine, it's at the bottom left corner of the screen when I have a session open.
Otherwise, you can right click on an attendee's name and select to send them an email. But it doesn't seem to allow you to select "all" or "multiple" attendees simultaneously. So, you'd have to send emails one by one, and I'm pretty sure that is not what you are wanting to do.
Also, it won't even let you do that individually with attendees that have not joined yet.
RickO
Re: Mirror PDF
Hello!
I followed your steps in the discription above and it works just fine. I would like to take it a step further though.
The reason I want to do this is to overlap to another pdf (drawing) to se if there is any differences between them. This does'nt work when my new mirrored pdf is blank when i go to Document> Overlap pages. (se attatchements)
Is there any way to fix this?
Also, just to be sure. Is "Flatten" the command with the weight? I have a Swedish version of BB Revu so I have a bit of language issuses.
Re: Selected tool will not release using escape key
You can find tech support in the app. Go to Help > Technical Support. Then you can search for your issue or go to the bottom of the page and select 'Submit a Ticket'.
I've always been pleased with Bluebeam's Support team. Maybe someone else will swoop in with an answer, but this is the best I an offer with my experience. lol
Re: Problem with creating formulas in v 21.4
Wanna make sure I understand. You made a formula-type custom column called "Qty". You want the expression to reference an existing column to get the quantity automatically added?
If so, here's how I think that would look:
Obviously, you can customize to your liking, but with this setup I clicked 'OK', and tested it out with no issues. Is this what you've done aleady?
Re: Takeoff Seaming diagram
Ah, 6'-7" wide roll. I was thinking sheets like plywood (my bad). If you just want a pattern, you can make your own. You can even import from AutoCAD.
👷♀️👨💼 Name: Joel Murphy - Project Technologist @ Kluber Architects + Engineers in Aurora, IllonoiIllinois
⛏️ My go-to Bluebeam feature is…
The Snapshot feature.
👨💼 Name: Ali
To have as much detail as possible ready on hand while presenting and checking the drawings, I can't get enough of shortcuts and always looking for feature updates to get me more out Bluebeam!
A.H
I'm Jonathan Roy a BIM Coordinator in Montreal, Quebec.
My daily goto's are: Status (love the new shortcuts), Filter List, Create Page Labels and Hyperlinking
I love attending all the Online BUG meetings from all over the world.
Hey Guys & Gals:
My name is John Sparks, Engineer III in Water/Wastewater
My go-to BB feature is the tool-box, great for my QA/QC and take offs.
Also, really like the overlay feature for review markups.
Charlie with the County of Merced in California. I am the supervising building inspector/plan reviewer/floodplain manager here.
We use Sessions for everything, but my go to is the Callout. It is great to have reviewers from all divisions using the Callout as the tool for corrections because it allows consistent summary correction letters to be generated.
