Re: Feedback : Find and Replace
Marco, has there been any progress on adding this to an upcoming release?
Re: Ability to Zoom
thanks, but I don't want to alter my settings. It's just a workaround, but if you want to zoom while drawing some markups, you have to press CTRL+SHIFT+ALT to be able to zoom and then press CTRL+SHIFT+ALT again to deactivate "ortho mode".
Re: Grouping Items - Tool Chests
In AutoCAD you can define a block with parametric parameters to drop into a file, it would come in matching the drawing scale, and then you could stretch it to the dimensions you want, click drop down options to switch between different types, or create an array with an input amount of objects. So for example a single button would drop in an anchor and you could switch between cast-in, wedge, epoxy, screw, undercut, then stretch it to the length and change the diameter all with the same dynamic block. You would only need one toolbox button for all the different sizes and types of a particular thing. One single block for every type of steel wide flange beam. One single block for every type of metal deck. etc.
Re: Locking one user's markups while allowing others to add new markups
Use a Bluebeam Session, that is exactly what happens. Otherwise for offline I think the only option is flattening the comments which is not ideal.
Re: Disable auto-fill for area measurement?
Thank you very much for your detailed solution — I really appreciate the effort you put into it. I'm actually already familiar with this approach. However, in my original question, I was hoping there would be a way to disable this feature entirely, just to be able to take a quick measurement without it being triggered.
hey @Shawn Dawson , thank you for your response! I figured the divided efforts werent too fruitful so this is great to hear! Excited to see what's next, and here to help! I work on the training side as a BCT so we hear things on a regular basis.
Re: Please add a setting for match point of sync'd views when view sizes aren't the same
Hey Jes, thanks for the reply.
By "make smaller" I meant stretching one of the view windows to a smaller size. I think when there are comments and you cycle through them, the focus will be on that location in each view (even if only one of them has the comments). But when there are NO comments, and you zoom in and out (wheel), it seemed to lock to the left.
Re: Cloud/Server Based Bluebeam Toolsets/ToolChest for Easy Management
Glad you have had the same thought. In today's day in age, it would be a great option to help standardization.
Re: Allow Conversion Between Markup Types
Yeah, I've seen something like this brought up before. I imagine someone will eventually merge the topics, but in the meantime, I wanna just say I would greatly appreciate this change. I don't usually need it, but I know it would make life a lot easier for many of my coworkers.
