Re: Grouping Items - Tool Chests
In AutoCAD you can define a block with parametric parameters to drop into a file, it would come in matching the drawing scale, and then you could stretch it to the dimensions you want, click drop down options to switch between different types, or create an array with an input amount of objects. So for example a single button would drop in an anchor and you could switch between cast-in, wedge, epoxy, screw, undercut, then stretch it to the length and change the diameter all with the same dynamic block. You would only need one toolbox button for all the different sizes and types of a particular thing. One single block for every type of steel wide flange beam. One single block for every type of metal deck. etc.
Re: Locking one user's markups while allowing others to add new markups
Use a Bluebeam Session, that is exactly what happens. Otherwise for offline I think the only option is flattening the comments which is not ideal.
Re: Disable auto-fill for area measurement?
Thank you very much for your detailed solution — I really appreciate the effort you put into it. I'm actually already familiar with this approach. However, in my original question, I was hoping there would be a way to disable this feature entirely, just to be able to take a quick measurement without it being triggered.
hey @Shawn Dawson , thank you for your response! I figured the divided efforts werent too fruitful so this is great to hear! Excited to see what's next, and here to help! I work on the training side as a BCT so we hear things on a regular basis.
Re: Please add a setting for match point of sync'd views when view sizes aren't the same
Hey Jes, thanks for the reply.
By "make smaller" I meant stretching one of the view windows to a smaller size. I think when there are comments and you cycle through them, the focus will be on that location in each view (even if only one of them has the comments). But when there are NO comments, and you zoom in and out (wheel), it seemed to lock to the left.
Re: Cloud/Server Based Bluebeam Toolsets/ToolChest for Easy Management
Glad you have had the same thought. In today's day in age, it would be a great option to help standardization.
Re: Allow Conversion Between Markup Types
Yeah, I've seen something like this brought up before. I imagine someone will eventually merge the topics, but in the meantime, I wanna just say I would greatly appreciate this change. I don't usually need it, but I know it would make life a lot easier for many of my coworkers.
Thanks for the detailed breakdown of how you're using Revu for iPad. You've clearly built a solid system, and we want to make sure you're set up for success as we move forward. A few important things to clarify:
- We don’t have the option to build on Revu for iPad. It’s based on older tech that’s becoming obsolete and unstable on newer versions of iOS, even with updates.
- Engaging with the Bluebeam Cloud iOS app now is the best way to influence what comes next. It’s the platform we’re investing in to give you more tools, better stability, and a path forward that doesn’t crash or lock you out of your work.
- Custom icons and symbols you create in Revu or Web can be saved to tool sets and used in the mobile app later this year, so you’ll be covered there.
Here’s where we are and what’s coming:
✅ Available Now
- Studio Sessions
Join Sessions, collaborate with markups, update statuses, and add comments. - Core Markups (11 tools)
Rectangle, Text Box, Arrow, Cloud, Callout, Cloud+, Ellipse, Vector Pen (Line, Polyline, Polygon), Highlighter, Pen, Image. - Basic Markup Editing
Move, resize, delete - Studio Projects (Read-Only Access)
View and browse files stored in Studio Projects. - Report Creation via Revu
You can continue creating reports in Revu today, as long as you’re using Studio or a shared cloud platform to maintain a single source of truth.
🛠️ Features in Development Now – To Be Released Soon
- Studio Projects – Check-in/Check-out Support
Enables file locking, version control, and accountability for edits. - Access to Local Files
Open PDFs stored directly on your device or through Files, iCloud, or supported DMS apps. - Offline-First File Sync
Mark documents and folders for offline access ahead of time—no need to open each file manually.
🧭 Planned for Late 2025 – Before Revu for iPad Retirement
- Tool Set Syncing
Tool sets created in Revu or Web will sync directly to the mobile app. - Measurements
Count, length, area, and perimeter tools. - Form Access via Hyperlinks to GoCanvas
While we’re not building forms directly into the app, we will support hyperlinking out to GoCanvas (or other apps). This gives you a way to launch forms from Bluebeam without needing built-in PDF form tools.
🔮 Planned for 2026
- Attaching Photos to Markup Replies
Currently, images can be placed on documents, but attaching them to replies is targeted for early 2026. - Adding Markups to Photos
Also planned as part of photo workflows in early 2026. - Custom Columns
We’ll support custom columns created in Revu. They don’t display in mobile yet, but that’s in scope. - Snapshots
Not yet available, but it’s on our short list of additional markup tools to support.
We’re building this for teams like yours, and your input makes a real difference. If you're open to sharing more, please send me a DM and I'd be happy to connect you with our research and design team.
You are in good company with that one, @bwhitlock .
A lot of times, that is brought up in context of sunsetting support for the iOS app. That usually brings up a lot of comments pointing out the shortcoming of the Cloud (compared to the full application) which is what iOS app users will eventually be relegated to using, unless they switch to a mobile tablet running Windows.
Latest:
Cloud/Server Based Bluebeam Toolsets/ToolChest for Easy Management - Bluebeam Community
Hey @bwhitlock, appreciate you sharing this! Revu for iPad had a strong foundation, but the tech made it tough to keep improving. That’s exactly why we’re rebuilding—to carry over what worked and push further. The goal is to give you something you can count on when designing workflows.
