Re: Tranfer of License to new PC
@Manuel A Santiago, From what I understand, you just need to download Revu 21 on your new PC and sign in with your BB ID.
(If you're using Revu 20 or earlier, you'll need to enter the license code that was emailed to you.)
Hope this answers your question.
Re: 🔦Real talk, real life: What's your go-to gadget on the jobsite?
My Samsung S25 Ultra is all I need - I can look at the drawings from Bluebeam Cloud and also take pictures and videos of progress, issues, etc..
Although I should say that my Thermos mug is also pretty handy in winter too!!!
For Punch-Lists in Procore, Viewing Blue Prints in DropBox, Sending & Receiving Emails, Taking Progress Pictures and Taking Notes, I would say the Apple iPad 11-inch: A16 chip, 11-inch Model, Liquid Retina Display, 128GB, Wi-Fi 6 + 5G Cellular, 12MP Front/12MP Back Camera, Touch ID, All-Day Battery Life is a perfect gadget.
Re: Improve the compatibility of polylength measurements and spaces
Hi all,
We do have plans to fix the issue described by Meri in the OP. We are planning to release this with an update later this year.
The issue described by Rupesh is one we also would like to resolve but we don't currently have a timeline for that. One way we were thinking of addressing this would be a method to "split markup by Space", similar to how Counts can be split by Space. However, if we did this, this would create multiple area measurements - one for each Space that area resides within. Would this be a reasonable solution? Can you provide specific workflows or examples of specific materials and floor plan conditions that call for this?
Re: 🗓️ July 2025 Challenge - Setup Spotlight!
I wear two hats at the office. I am an Electrical Estimator, and my secondary hat where I create/Engineer drawings.
I set up two different profiles, with corresponding tool sets to match each role. Estimating Profile for takeoff, Engineering Profile has everything I need to create and mark-up drawings.
Here are screenshots of both profiles.
Estimating Profile:
Engineering Profile:
Always open to suggestions if you’ve got ways to make it even better.
Re: Log out of BB when closing the app
If I understand you correctly, my guess is that the idea behind subscriptions is that it is 1 per seat. So Bluebeam appears to be designed around this principle meaning the user would not have to sign-out if each user has his/her own personal computer. In a few words, you don't sign-out of Bluebeam; you just simply LOCK your computer and go to lunch.
Milwaukee Packout! kit your sh*t and its always together.
Re: Change Case command for Text
This would save copying text to MS Word, converting, and pasting back again. Please add the feature
Reinstalled and working fine now. I appreciate everyone trying to help!
Re: Revu has high memory usage
Have you tried adjusting VRAM settings? This is where the system can set aside some disk space and use it as Psuedo-RAM. This is located under advanced system settings. Two things I usually adjust under "Performance" settings:
- Visual Effects: Turn everything down except Smooth Edges of screen fonts. This can reduce the system load when switching windows and programs. Little things will change like when you move a window it just shows an outline instead of the preview of the window moving.
- "Advanced/Virtual Memory": I will usually just turn off the "Automatically Manage" and switch to "System Managed". This way the system will pull disk space as needed. You can always set manual , and it gives a current and recommended at the bottom of the page. I have heard that this works best when using rounded bit values (divisible by eight), but I have never had a problem with it either way. Requires system restart to take effect.
