Re: Revu has high memory usage
I am working at 960 right not but went to import drawing from file and it went up to 1157 but Google Chrome is in the lead. only 1188. I have heard Candy Crush is a memory hog lol. Have a good evening
Thanks Isaac,
I will play with it and see. I appreciate your help. Have a good weekend
Re: Convert shape to Area
I was working with a consultant who painstakingly marked up 90 floor plans with the shape tool (multiple zones on each floor) then asked me to tell them the area of each …… 😭
I have also faced similar situations (but not to that scale)
Please add this function
Re: The Ultimate "Start Here" Guide for Owner/Operator
I also agree that Bluebeam University is a good start. Revu Help is also easy to navigate (https://support.bluebeam.com/online-help/revu20/Content/RevuHelp/Dashboard.htm).
I was hired at my current job because of my Bluebeam experience and have created several instruction manuals based on the Revu Help website. Hiring a certified Bluebeam instructor can get pricey, but if you can get customized one-on-one training, it is well worth the cost. I have been using Blue beam for well over a decade and it is a powerful tool to bid faster and more accurately.
Good luck on your journey!
Re: Revu keeps windows pdf file status as open or locked even after closing the file or closing Revu
Definately experienced this as well
Attached is a PDF Template in Red, Green & Blue.
Helvetica Font used since all PDF versions support it.
by the way, I just discovered that ALT + 7 also does the bullet point symbol!
Re: I want to be able to “edit” the count measurement results
Don't forget that you can select multiple counts for this by shift-clicking
Re: Already made templates
One more option, which worked for me in the past. Is try to open the file in in Adobe or another PDF editor, and then save-as a new file name. Then reopen in Bluebeam and see if it clears the issue. This way you might still be able to edit the document normally.
