How can I change measurements, dimensions & calibration, from architectural to engineering units?
Ah, yes. I poked around and found this. When a dimension is selected, these options show up at the top. Switch to the ft option and it will give you decimal feet.
You should have engineering scales as an option when you set the scale on the sheet. Are you looking for something other than what's available or do you mean something different?
https://support.bluebeam.com/en-us/revu/how-to/set-the-page-scale-on-drawing.html
Luke thanks - I mean different. After setting a custom scale for a certain drawing sheet (that's an engineering plan) I want dimensioning (measurements) to show as e.g. 23.25 ft, and 106.5 ft, and not as e.g. 23'-3", and 106'-6".
In other words decimal feet.
So who remembers poking around in units menus in AutoCAD and discovering that they go all the way up to LIGHTYEARS!?!
Can our .BTX tools be used in the Bluebeam Cloud for iOS? If yes, please let me know how. If not, will I be able to before the iPad app is deprecated at year end? Thanks, Dustin
For some reason my search tool doesn't work on certain pdfs and dont know why this is. Is there a easy fix for this?
I was wondering if anyone knows how to create a digitally signed signature (instead of using conventional digital signature offered)? I'd like to create a permanent image of my own signature on paper, store it and certify it if possible. Any suggestions are appreciated.
Can't find the split tool for polylines in bluebeam 2021. Youtube tutorials show the option, but it's missing for me. Don't want to redo all my markups. Help!
Working on a form and added the "reset form" button and it works as always. I'm trying to add a "print form" button but the issue I'm having is that when I click my print form button it will work once, but if you press it again, it won't work thereafter. I submitted this on ChatGPT and it had several options, but none of…
I got an email this afternoon asking if I wanted to sign up for this. "Interested in trying new Bluebeam innovations before they’re released to the public? You’re in luck!" It sounded interesting. I clicked the link, but the USA BBID doesn't take you to a login page. Is anyone else having this issue?
how to i change the line density when using the measuring tool? when i pull a measurement i click and the measurement stays as a thin blue line and not a thicker line
I am working on creating a custom toolset for my team to quickly calculate concrete and steel reinforcement quantities for bridge components. In order to do this, I have added quite a few custom "columns" which take inputs or store tool-specific variables. These are displayed in the measurement properties tab under…
I am using quantity link to get length takeoffs from my PDF directly to excel. I can link a cell to a certain measurement type (length, area, etc.) but can't separate it out from there. Attached picture might make this make sense. I want the 'Length 1' measurement to go to cell B2 and the 'Length 2' measurement to go to…
Having problem opening a file downloaded from https://au.i2.saiglobal.com/ in Revu BlueBeam. Below is the error: "There is a problem with this protected document. It may be damaged. Please contact the publisher for a clean file." Currently using Revu Complete 21.5. Greatly appreciated if someone can help one this.
