Re: I have duplicate "My Tools" chests?
Yes, this has something to do with the storage location if it is anywhere other than the default. Mine are stored in Dropbox so I'm encountering this.
I've been in contact with Bluebeam Technical Support and they are looking into this issue. No fixes yet though!
Re: Add a button to re-enable the Title bar when hidden
Agreed! or at least have the title bar show up when the mouse hovers next to it. It can get very frustrating for someone that has no idea how to bring it back.
Re: Adjusting Properties in Bulk on Forms
Can you select the fields all at once using the Forms panel? With the fields selected, open the Properties panel. Under Appearance, you should be able to adjust the Font and Font Size.
Re: Option to select what split windows/ detached pages to be synchronized.
At least as a temporary solution, could you open a second instance of Revu for the items you don't want the synchronization to affect?
Carina
Re: Measure length along a sloped curve with the Perimeter tool
So you're looking for the real-world length (in three dimensions) of the handrail. You can do this easily for straight runs but not for curved runs, correct? How do you do it now (what's the math/method/formula?)
My instinct (and what you're probably doing already) would be to take the length from the plan (a) and the stair rise (b), then use the formula a² + b² = c². Solve for c. Keeping in mind that handrail extensions might be level but it looks like you're not dealing with that in your example.
I used BB to build and track my March Madness tournament bracket.
It also makes good memes. When we got a new fridge in the office, I put one together to announce the ice maker was ready for use, after its 24 hr initial cleaning period. It was cold and snowing here that day….
Re: How can I use iPad for on site inspection with specific mark-ups (tool set)?
Ok. Thank you. I was able to do it with that app. I appreciate the help.
The Bluebeam app being retired is the stand alone Bluebeam app right? Not the cloud app. Are you using the Bluebeam app being retired or the cloud based on? If your using the one being retired, does that let you have tool boxes?
I am using the cloud based app. Where I have to start a session on my PC and then I can open it up on the app. I dont see the option on the cloud app for the ipad for tool boxes.
What I am trying to do is just as you said. I wish I could have tool boxes and then I can just one click the items I need right onto the page and edit/copy. I believe this was coming but is not here yet. I am trying to find a way to do this in the meantime but cant figure out how.
Yes it is the stand alone app from my understanding! The only way I know this workaround works is in that app and not the cloud one yet.
The iPad app is currently being phased out. See this link for that thread.
For workflow, im not sure what your using the app for in field, but I have used this work around for a few punch lists. I started new a tool box with several text box saved with standard callouts such as PT, RCP, LIGHTING, REPAIR, DENT, CORRECT, REF., etc… and saved each one in that tool box. This allows them to be one click to select - one click to paste. This is the fastest method I have found for large scale markups in field in the app. Easy to repeat and quick to edit if I need to edit a specific note such as PT - WRONG SHEEN.
