Re: Scroll vs Zoom
This is good to know, thanks! I've been using Bluebeam for 25 years and never realized I could toggle between Zoom and Scroll in this way.
RickO
Re: Scroll vs Zoom
Good looking out, @Luke Shiras. I like to go over the preferences with new users too, so that their default action makes the most sense to them and then make sure they know they can toggle the wheel function by holding CTRL.
As a follow up, I submitted a support ticket through Revu, and Technical Support responded back confirming that this is not currently supported.
Re: Defaults
Re: Multiple markup default settings
You know what, I just figured it out:
Create an object like a callout or cloud+ with the properties you want
Right-click and add to Tool Chest
Right-click on the tool chest icon that was just created and change from "Drawing Mode" to "Properties Mode"
Re: Paste in Place not pasting IN PLACE - help!
Just an interim update - I sent them 2 documents, one to copy FROM and one to paste in place TO. I also left 2 markups on the TO doc so they could see how far off the page the pasted ones appeared. They said they could see those markups (way off the page) and were able to recreate the issue. I also told him this has happened with many other documents I'm working on. He said he's brought in their research team for further review.
