Re: How to apply AutoCAD document data to Bluebeam Printer
Have you tried below?
- Bluebeam CAD Plugin: If you have Bluebeam Revu CAD or eXtreme, you can use the Bluebeam plugin for AutoCAD. This plugin allows for more advanced PDF creation options and might help you include additional metadata.
- Custom Properties: You can manually add custom properties to your PDFs in Bluebeam Revu. After creating the PDF, open it in Revu, go to
File > Document Properties
, and add the necessary DWG data manually. - Layer Information: If you need to transfer layer information from AutoCAD to the PDF, you can create a separate PDF for each layer using Bluebeam’s CAD Plug-in and then combine them into a layered PDF in Revu.
- Using DWG Trueview: Another approach is to use Autodesk’s DWG Trueview to convert your DWG files to PDF, ensuring that the metadata is preserved during the conversion.
We have the same problem… our lead reviewer consolidates and verify comments from engineers. any conflicting comments or comments that is not needed must be remove. The lead reviewer finalized comments before document controller sends it to the originator. If the review lead cannot remover or delete comments that is not needed it is causing a bottle neck / delay. Please make this happen. The session report should capture any removal deletion of comments so there is a security in place.
Re: 📢 The Future of Bluebeam Cloud ☁️
Excited to hear about the upcoming release of the studio project on the web in Sep 2024!
Some suggestions for Bluebeam Cloud's development roadmap:
- Customizable workflows for design/construction,
- RFIs, Submission, Site Inspection, Defeat Management, Site Progress Tracking
- Dashboard to track workflow status and user tasks,
- Project Forms (SmartPDF, e-forms), and
- Notification Management
- Open APIs
Import - Ctrl + F3
Dear All,
I have to highilight that the function "Import" is missing into the MARKUP tool bar option. The only way to use it is only with the Ctrl + F3 keyboard shortcut and only if is already in the user's previous knowledge.
The precence of the button into the ToolBar would help users in knowledge (almost impossible in this way) and in identifying this function in a performant way.
thanks in advance,
Best Regads,
Stefano Tattarletti
Re: Import - Ctrl + F3
I had a look, and I agree that I can't see it there, and I am unsure if I can add it to a new Toolbar.
I feel that it's in an intuitive location, but it requires a few clicks to get there.
I talked to someone today about Importing data from many files. I plan to look at Scripting for Importing Markups and then incorporate that into a button and even a Bulk Script Import Markups workflow. I don't know if this will work, but it's worth trying!
Re: Tool Chest Tool
I helped a customer with a similar question only last week. I see your point and think it's an interesting idea, but at this point, Bluebeam can't do that. So, what can we do?
I will be general without knowing what you are creating a quantity take-off for.
The key is to use Choice Columns and import data from Excel as a .csv file for each Choice Column.
Align the Choice Column options to the Subject name of the Markup (takeoff).
Let's use an example of an electrical item: lights
1. Build a toolset of all the fundamental types: downlight, spotlight, striplight, etc. E.g. 8 different types
2. Create a Choice Column of the different globes needed: fluorescent, LED, Edison, etc. E.g. 5 different types
3. Create a Choice Column of the different lumens needed: 40, 60, 80 etc. EG 6 different types
At this stage, in this example, you have 8 types x 5 globles x 6 lumen options = 240 potential options.
4. If you want specific part numbers, create a list in Excel, import it via .csv into a Choice Column and use it in your takeoff
Have a look at this support article and look out for the section "Import material choice items"
Re: 🗓️ August 2024 Challenge - Custom & Favorite Tool Sets!
I use tool chests to collect information in a consistent way. See pic below.
With a tool chest and a custom filter, it's a good way to say to a group of people: here is the document, here are the buckets of information I'm expecting to get from you. Now go collect.
If you're into the details: 1. We keep all of our PDFs in sessions so we have to have a page at the back of the document to bring in the layers that align to the tool chest. 2. I have to confirm that custom filters transfer with the profiles but i would assume so, otherwise setting this up manually on 20 computers would be a pain. 3. I find that for some people, to get buy-in, they want to see some kind of output, so you can transfer the tool chest data to a standard report → You have to download the data table to CSV and i have an excel file that can match the heading name in an excel table column to the text box field name in bluebeam to transfer the info another PDF. Then you can have a nice PDF containing the pre-structured information that they can hold in their hands. *i don't do this often because it takes so long and it's a static document.
Agree 100%. Bluebeam for iOS is a great product for viewers, especially in underground project or other types of project where there's no access to internet on site. Unfortunately it is a very outdated product that should have received it's share of love ages ago.
I have several projects where I use Revu iOS offline as a viewer, except for a few "hotspots" where the iPads can sync with the latest changes.
Re: Leave Bluebeam Cloud Alone?
Its distressing to know they're doing away with the RFI, Submittals, and Punch system without a replacement. I watched the webinar last week and its not a good replacement. Its half baked and clunky. We have contractors that need a simple and intuitive interface as possible. What was demonstrated is not at all simple. Disappointed in this decision.
Re: Web Based Add-in
Hi Jen. I am curious if anyone has reached out regarding the web-based add-ins you wrote about. I submitted a ticket to Revu about this earlier this morning.
