Re: Convert shape to Area
I was working with a consultant who painstakingly marked up 90 floor plans with the shape tool (multiple zones on each floor) then asked me to tell them the area of each …… 😭
I have also faced similar situations (but not to that scale)
Please add this function
Re: The Ultimate "Start Here" Guide for Owner/Operator
I also agree that Bluebeam University is a good start. Revu Help is also easy to navigate (https://support.bluebeam.com/online-help/revu20/Content/RevuHelp/Dashboard.htm).
I was hired at my current job because of my Bluebeam experience and have created several instruction manuals based on the Revu Help website. Hiring a certified Bluebeam instructor can get pricey, but if you can get customized one-on-one training, it is well worth the cost. I have been using Blue beam for well over a decade and it is a powerful tool to bid faster and more accurately.
Good luck on your journey!
Re: Revu keeps windows pdf file status as open or locked even after closing the file or closing Revu
Definately experienced this as well
Attached is a PDF Template in Red, Green & Blue.
Helvetica Font used since all PDF versions support it.
by the way, I just discovered that ALT + 7 also does the bullet point symbol!
Re: I want to be able to “edit” the count measurement results
Don't forget that you can select multiple counts for this by shift-clicking
Re: Already made templates
One more option, which worked for me in the past. Is try to open the file in in Adobe or another PDF editor, and then save-as a new file name. Then reopen in Bluebeam and see if it clears the issue. This way you might still be able to edit the document normally.
Re: Layers freezing up
Are you the admin for all the layers? Sometimes the layer but not be able to be organized because of the way the pdf is set. Try to save layers in one zip folder.
What's your dream project? 💭
If you had the chance to build, design, or create anything with a team using Revu, what would it be? Dream big! Is it a sustainable skyscraper, a reimagined earthquake proof building, or a super cool stadium?
Share with us what your dream project is!
eperius
