Re: Quantity Link
I hope that in the next update, Revu can introduce this feature. When filtering selections by subject, location, or label, it should refine the results effectively. Displaying hundreds of items despite applying filters defeats the purpose of having a filtering feature. It seems like the Quantity Link feature is only suited for small jobs rather than large-scale projects. Improving its functionality would make it more efficient for handling bigger workloads.
I would greatly appreciate it if you could demonstrate how Excel Power Query can effectively achieve this goal.
I have been getting into the habit of processing OCR on all my major files to save myself some headaches down the road when needed to find info quickly. When dealing with old plan/file scans on the daily, being proactive saves me oodles of time. OCR for the win!
Construction User
I hope to see alot of tips and tricks from everyone. This will be a great group!
Stamps
I use custom stamps regularly and find panning up and down in the dropdown to be annoying since the icon to pan up or down is so small and when my pointer goes past it the drop down disappears, then I need to find my stamp again..!
Please fix..
👷♀️ Name: Myranda Kelly
⛏️ My go-to Bluebeam feature is a the Measurement Tools!
📷️ A picture of you on the job: Ribbon cutting for substantial completion of our newest monument sign:
Go to Feature: Volume measurements and Legend
Re: Thumbnail Navigation
I am guessing that the thumbnails would have synced up if you activated page 83 by clicking on it after navigating to it. Could that have been the issue?
My thought is that you had a tool active in page 250ish so that is where thumbnails went.
Re: External Script Engine
The problem is a sneaky one, you need to escape the single quotes around comment and ten using the pipe character.
…\scriptengine.exe "Open('.\test.pdf') MarkupSet(1,'KGYCQZMGMQHHPNJO','{|'comment|':|'ten|'}') Save() Close()"
Let me know if this works!
Re: Stamps drop down
@JBrunelle, Seems like you are using stamps for all your markups. My suggestion is that you use the Tool Chest for your standard markups (like the pole lights, etc.). Stamps are better suited for items you want to include on every page, such as approval blocks or signature boxes. This will also eliminate the frustration with the dropdown navigation.
Hope this helps!
