Re: Who's joining me at UNBOUND September 30-October 2?!
I’m gonna be there!! Going to try to make all 3 days.
One of the first things I do when new drawings come in is add a standardized header and footer to every page. I created a custom template in that includes the project name and the date the drawings were received. This helps keep our files clean, consistent, and easy to reference, especially on fast-moving jobs.
The best part? Bluebeam has a powerful feature that lets me apply these headers and footers to multiple documents at once, even if they aren’t open! The option to select a document, an entire folder, and even choose to include subfolders, is a huge time-saver when dealing with large drawing packages.
Re: Request for Quick Dark Mode Toggle Button in Toolbar
Thank you so much for pointing that out! I wasn’t aware of the Dark Mode icon in the navigation bar—this will definitely save me a lot of time. I appreciate the helpful tip!
@acastillo - In your Navigation bar (bottom of screen), there is a Dark Mode icon you can click to change modes.
The shortcut of CTRL + 3 is another option.
Re: "COMMENT" COLUMN IN TOOL CHEST
Actually, I take that back, well at least some of it. I just checked and you can now HIDE the Comment section.
and just slide the column over, and now its GONE:
I also see that you can pretty much hide all columns you want, so this issue is FIXED!
Re: Trenching tool
hi @Doug McLean
Unfortunately, I don't my set isn't really like this.
My workflow does involve does ultimately work out the volume of muck excavated from drainage trenches, but I use Excel to do the calculation bit as there are too many variables for Bluebeam to deal with. For example, the trench width will depend on the size of sewer pipe being installed, the depth of the trench, etc..
This is a link to demonstrate what I end up with
For this example, I'd probably look at a couple of custom columns for the top and bottom widths of the trenches. You might be able to throw in a couple of default values or even use some kind of formula. However, I would it will end up needing a lot of manual overriding which I think @Moises’s iPad is actually trying to get away from.
Re: Bluebeam Sets won't print the latest revision
Ah, I see now. I just tried it and it printed the pages I asked for (Even pages of PDF-1, 3-6 of PDF-2) so I see how it should work. Not sure why it's not working correctly for you. May need to reinstall Revu to fix a corrupted file, library, or path.
Re: I am politely begging you to add the ability to center hatch pattern - tile drawings
100% this is a problem. Don't get me started about not being able to rotate the pattern…
Re: Any options to have BB studio reconnect automatically?
It occurs to me that if Bluebeam can't/won't implement auto-reconnect functionality, then at the very least give us an option to prohibit working offline. It's caused enough problems that I'd rather users couldn't see the PDFs at all during an actual extended internet outage. That seems like it'd be less of a problem than the silently-going-offline issue.
