Re: How to Copy-Paste and Edit Text boxes with Formatting
@Luke Shiras, I love the way you you did that. Looks real neat!
I think that this can also be resolved if we just had basic Microsoft Word Style Formatting in text boxes. It's an issue that has been brought up many times. Lets make in a priority!
Who's joining me at UNBOUND September 30-October 2?!
We've reimagined what XCON looks like and are excited to bring UNBOUND to our Bluebeam users and the industry!
Need to convince your boss? Easy! You'll be able to:
- Put into practice what you learned: We don't know what we don't know - right? Attend Bluebeam and peer-led sessions!
- Expand your network: Meet the faces behind the names!
- Innovation & industry speakers: Check out our keynote speakers to help you get inspired & hear first-hand what's on the industry leaders' minds.
Register now before early bird pricing ends at the end of May & get 30% off reg. with discount code: UNBOUNDCOMMUNITY
!! Session Catalog Coming Soon !!
- This will be released in early June, but I can promise you…the session lineup will be 🔥
- I've been told some Communities members have been selected to speak!!
Join your industry peers IRL for endless networking & FUN!:
- September 30: Communities Welcome Reception (BUGs + Online Community Members)
- September 30: Oktoberfest Unbound kickoff!
- October 1 & 2: 15-20-minute meetups throughout the conference in the Get Involved BB hub!
- Oct 1: Unbound Party @ the National Building Museum
So if you've ever been to XCON…just wait for Unbound!
Re: Sequences need drastically improving
I would add to @Brandon Costlow's comment regarding leading zeros. It would be extremely helpful if the sequencing feature included an option to define the number of digits, so that with three digits, for example, the sequence would display as 001, 002, ..., 010, up to 100, and so on.
Re: iPad App Overhaul Desperately Needed
@Jeret Buerger - Buehler, Thanks for the thoughtful feedback. It’s clear we’re not meeting expectations yet, and that context helps. We’ve been focused on supporting Studio Sessions and other ways to get into files, whether from Projects or local storage, but that’s delayed markup improvements. A full offline experience is coming later this year, followed by tool sets and measurements. I’d love to know if anything else is holding you back. I'll send you a DM with more details.
Re: PDF Graphical issues with markups/snapshots
After working with technical support, the following has fixed it. I am pretty confident I have toggled through these settings and tested with this specific setting, but as of now, this has fixed it and may help others having the issue. It may present again as I work on these older PDF's I have with tons of markups and vector snapshots, but hoping it sticks!
Re: Bluebeam Sets won't print the latest revision
Thanks, @Jes Stafford,
Yes, we have tried Sets > Print Set > Print Latest set (that is our default method).
We have also tried Sets > Select Latest Revisions > Publish > Combine, and
Sets > Select Latest Revisions > File > Export and
Sets > Select Latest Revisions > File > Print
Each option wants to print ALL pages of each document/PDF instead of the intended: just print the latest versions of the sheets from all documents in order.
Carina
I'd like to add to this recommendation if you'd allow it… I wish we could assign a certain number of digits with automatically filled in trailing or leading zeros. Right now, if I want to maintain 4 digits to name wire runs on a job, I start with a sequence that has two leading zeros, then when I get to A009 I have to switch to a sequence that only has one leading zero. Even that gets to not working relatively quickly on larger jobs as A099 would be the limit for the one leading zero. Having to make multiple sequences to maintain a uniform naming convention is pretty annoying and would be much better if the settings of the sequence allowed for a smarter numbering system. Our naming is actually more complicated than this because we use decimal places for runs that share either a line- or load-side termination. For instance, a conduit may be able to house three circuits. One circuit terminates in junction box 1, while the next one terminates in j-box 2, and the third in j-box 3. If the main run is named B001, the other two would be B001.1, and B001.2, respectively. I don't expect the sequence tool to be able to handle this strange naming convention, but it would really be great to have the main runs sequence more intelligently at least.
Seriously, a cloud only app does not make sense for IPad users. Most likely the reason we are using an iPad is because we are in the field at a construction site, customer site, traveling, etc. So to assume we are tied to our desk with a speedy internet connection is simply out of touch with your customers.
Please upgrade the app.
Re: Visual Search only captures entities at the top of the page
Well, @Tom.Stonehewer , I'm not certain this will do the trick, but I sort of had a similar experience when I tried to make a drawing like they one you show here. What I did was change to the most crude search settings I could come up with. I unchecked 'Limit by Section' and dropped sensitivity to 0. I got several false positives but it got me the full page at least. From there I was able to make a few changes to the sensitivity and even eventually turned back on the 'Limit by Section' option. My final settings that gave me the exact results I wanted are shown below.
'Search for Fine Detail' actually got me very close, but missed one. Turned that back off and bumped the sensitivity up a bit to get it just right.
Simple. In the Sessions settings —> Permissions tab —> Applied Permissions list, new option "Markup Edit": Deny/Allow. There are already 6 options in the list, I don't think adding another one should be a problem.
By the way the "Full Control" option is not full control, cannot "control" markups. 😣
We don't want all sessions to have the markups editable. We only want the option to turn it on/off by the admin when required.
