Re: Has it been a year already?
You've been far from a bother! 😁
Your posts have been helpful to fellow Bluebeamers here and truly appreciated by the Community team. Thanks for being part of the community! 🙌
Marco M
This just in…
I've been bothering people here for a year now. :-)
Re: Stitching Drawings Together
I like the stitching feature. However, I have found that after stitching some drawings together, REVU® creates a document that allows all of the data from the Spaces used for stitching to fit on one page. (in my case it is 200.00 x 61.83 inches). However the Drawing is no longer searchable using the search function in REVU®.
When I try to run the OCR I get the dreaded "Object reference not set to an instance of an object" error.
How can I make this new, rather large document, searchable?
Please advise,
Re: Search text result export to Excel/CSV
@SGalmozzi, I can think of one workaround, perhaps if you Highlight the results, and then export those highlights.
For the last month or so, I've been working on developing onboarding training in Bluebeam. The goal is to bring in new foremen or project managers, and teach them how to use our company workflows to manage common tasks of their new job roles. Along the way I've developed a dashboard for sharing my notes, videos, and more. Before this, I never used a dashboard, but I've been having fun learning and exploring ways to streamline what I provide these guys.
I just can't wait for some of the features in the Beta program to get released so I can have fun teaching those new features too. :)
Re: Restore Last Closed Tab/Tabs
There is a work around!
Maybe an extra click or two, but if you open the File Access side Panel - look at your list of recents and the last one closed is the first one listed - should be what you want to open.
Re: Highlight in the find/search command with a different color than blue
I would really love it if clicking on the search result resulted in the item being centered in the view window instead of in anchored in one of the four corners. The current behavior means I have to look in all four corners, and then drag/pan that region to the center of the screen so I can read everything around it. Please, just center it by default and save me the steps and frustration!
✴️ Feature Highlight: Thumbnails Panel
The Thumbnails Panel in Bluebeam Revu lets you easily view an entire document. You can jump between pages, rearrange them, rotate, delete, or even drag and drop. It’s a simple way to manage multi-page PDFs without getting lost scrolling.
Do you use the Thumbnails Panel to manage your documents or have a tip for keeping documents organized?
Marco M
Reuse or Save Page Label/Bookmark Page Region selections
My issue is a question/idea but is it currently possible to save/reuse selected Page Regions made when creating new Thumbnail Page Labels or in Bookmarks.
We use the Page Labels/Bookmarks 'Page Region' feature to extract out drawing title block information, but I have to redo the same region selections for each new package we get in even though they are on the same title block each time.
We are doing a QA check to see that the supplied PDF metadata matches the supplied drawing file (and it does not in a lot of cases).
It would be great if there was a way to save a 'Page Region' selection to import if on the next set.
Re: Is it possible to compare and also overlay PDFs?
We were able to do this but we had to re-save the original files before doing the Overlay/Compare.
1. Use File → Create → From File in the menu and do this for both original files (File 1/2).
2. Create Overlay PDF and select File 1 then File 2.
3. Create Compare PDF selecting File 1 then File 2.
4. Import the Markups from the Compare '_Diff' PDF into the Overlay PDF.
Bluebeam Support initially helped find the procedure when we were having issues with markups being rotated etc.
I think the 'Create From File' cleans out all the junk from when the files were created and kind of standardises it.
We now do this almost daily now on PDFs from consultants and PDFs we have generated in AutoCAD/MicroStation/Revit.
