by the way, I just discovered that ALT + 7 also does the bullet point symbol!
Re: I want to be able to “edit” the count measurement results
Don't forget that you can select multiple counts for this by shift-clicking
Re: Already made templates
One more option, which worked for me in the past. Is try to open the file in in Adobe or another PDF editor, and then save-as a new file name. Then reopen in Bluebeam and see if it clears the issue. This way you might still be able to edit the document normally.
Re: Layers freezing up
Are you the admin for all the layers? Sometimes the layer but not be able to be organized because of the way the pdf is set. Try to save layers in one zip folder.
What's your dream project? 💭
If you had the chance to build, design, or create anything with a team using Revu, what would it be? Dream big! Is it a sustainable skyscraper, a reimagined earthquake proof building, or a super cool stadium?
Share with us what your dream project is!
eperius
Do you have any active filters? Clicking "All" above the desired column will give you your choices.
The filter list above will not let me change any of the information. I haven't touched the layers, this sample drawing is under the Welcome to Revu. The same thing happens for all drawings I open.
@nexlevel801 Thanks for sharing this tip. Using Alt+0149 for bullet points is an interesting approach (cumbersome, but interesting). How are you handling the indentation for items like 3.1, 3.2, and 3.3?
There is not an option to UNFLATTEN. Neither in the documents tab or shortcut. :-( and when i try to alter the security by changing the permissions, nothing happens when i click on change permissions. …
What is a "nuclear" option?
FeliciaM
