I am working on expanding the Bluebeam Revu training in a recorded and reviewable format for the firm I work at for part of our internal 2025 goals. I have been making small, 4-8 minute training videos called BugBites. (my last name is Roach so it’s on brand😊)
The one I will be researching and creating this month, or skill seed I am planting per Mays challenge, is the highly requested Overlay Pages feature. I’m excited to see how this can fit into and improve our QA/QC workflow!
Re: Markup Summary
@Luke Shiras, Thanks for the clarification. I usually export to Excel, so I haven’t encountered this issue before. I tried manipulating the PDF export, but regardless of the setup, it still includes a “Total Count” heading. This problem doesn’t occur when exporting to Excel.
BCP Update Coming: Exam Update Releasing June 3rd - Get ready for the latest changes!
Hello Bluebeam Community!
We are excited to announce that the Bluebeam Certified Professional exam will be updated effective June 3rd. This update includes stronger task-based questions, revised exam objectives, and a new limit on exam attempts. You can see all details and how to prepare here.
I only want this feature when I need to fix someone else's typo, so I can live with the current limitations. Not being able to make edits to other people's markups preserves the integrity of the authorship.
To further the discussion and get a better understanding of WHY we should be able to edit other's markups, please reply - in detail - your workflow that requires the ability to make those edits.
Are you consolidating similar comments? Editing to use consistent language? Revising sketches or notes? Maybe you just want to assign markups to a discipline or change colors?
Describe what changes you want to make and why it has to be edited vs other solutions.
Hi @Colby Gallagher - TfNSW - DE Manager,
Thank you so much for reaching out to us about allowing users to edit other people's Markup in Studio Sessions, and we've taken note of your request. Could you share anymore detail about why your review manager would delete a comment or Markup?
Please let us know if there’s anything else we can do or if you have any other questions. We look forward to potentially collaborating on future projects.
Alan A.
Re: Creating repeat comments from standard list
You can use the custom columns feature to import choices from a list and then set the custom label to be the contents of that list. Should do the trick.
I cannot emphasize enough how much this function is needed for our workflow. On larger projects it is a full time job for someone to manage markups, and currently it all has to be done "offline" while everyone waits for the documents to be available on the Bluebeam Sessions again.
Hi everyone!
It’s the perfect season for growth, and this month’s challenge is all about letting your skills blossom! Whether you’re exploring a tool you’ve never used, learning a shortcut that saves time, or leveling up an existing workflow, we want to hear about it.
What’s one Bluebeam skill you've recently learned or plan to explore this month? Share what you tried, how it helped, and the impact. Your insight might just help out a fellow community member.
🏅 Recognition 📈
Participants will earn a unique challenge badge and points to help level up in the community!
🤝 Share & Comment 💬
- Post about a feature, workflow, or habit you’ve learned or improved.
- Join the conversation! Ask questions, offer encouragement, and pick up fresh ideas from fellow community members.
📚️ Resources 🧠
Marco M
Re: Show list of ALL open files in file access
I would also suggest making the list of open files editable, allowing users to close unneeded files and rearrange tabs via drag-and-drop for better organization.
Re: Textdurchstreichung für die Kennzeichnung "Falsch"
I like the first idea…
When checking the PDF files, it is necessary to mark individual text passages as "False".
Crossing out as a cross/X quickly becomes crooked and crooked, because you have to draw two lines manually.
It would be better to have a way to draw an area and in this rectangle a cross/X appears, whose color and line thickness I can define.
Wouldn't that be a good idea for a new function?
The second idea sounds less intuitive and might lead to two markups instead of just one.
Or as an alternative suggestion: "diagonal reflection at the center"
I draw an oblique line e.g. with 350 °.
Then I would like to see a function (short-cut) that aligns this marked line twice at the same position and in the opposite diagonal (according to the example with 10°). Thus, both lines would cross in the middle and a clean X-cross is created.
I bet this could be solved with a toolset, at least for now.
