Re: Show list of ALL open files in file access
I would also suggest making the list of open files editable, allowing users to close unneeded files and rearrange tabs via drag-and-drop for better organization.
Re: Textdurchstreichung für die Kennzeichnung "Falsch"
I like the first idea…
When checking the PDF files, it is necessary to mark individual text passages as "False".
Crossing out as a cross/X quickly becomes crooked and crooked, because you have to draw two lines manually.
It would be better to have a way to draw an area and in this rectangle a cross/X appears, whose color and line thickness I can define.
Wouldn't that be a good idea for a new function?
The second idea sounds less intuitive and might lead to two markups instead of just one.
Or as an alternative suggestion: "diagonal reflection at the center"
I draw an oblique line e.g. with 350 °.
Then I would like to see a function (short-cut) that aligns this marked line twice at the same position and in the opposite diagonal (according to the example with 10°). Thus, both lines would cross in the middle and a clean X-cross is created.
I bet this could be solved with a toolset, at least for now.
You know it's good when software keeps surprising you after many years of experience with it!
Re: Grouping Tabs for Open PDFs
Sometimes I use Microsoft Edge to group the documents and get a visual idea from there before moving to Bulebeam. Navigation is extremely easy that way.
Re: Creating repeat comments from standard list
Hi RTao,
I understand you're looking for a database lookup function similar to what you've used in other complex BIM software. Unfortunately, Bluebeam does not offer this feature. However, there are alternative methods you can consider:
- ToolSets with Prewritten Comments: You can create ToolSets that include prewritten comments. These ToolSets can be shared across your office, ensuring everyone adheres to company standards for comments. If you're already familiar with ToolSets, this might be a straightforward solution.
- Using Code for Comment Distinction: When I was drafting, I used a coding system to differentiate between comments. For example, you could add a comment like "PL01" to reference your Property Line 01 comment. This method allows for quick identification and consistency in your documentation. You can then add a cover sheet (or via Scripting) that shows the code and description as a one pager.
I understand these are work-arounds, potentially someone else in Community will have a better answer.
Agree! Upvoted. This would be a great feature as I tend to leave the contract documents open for my most active projects. Those usually include at least two tabs - one for drawings and the other for the project manual (specs). A lot of times, there is also a tab for revisions.
Re: 🎉 Congratulations April 2025 Leaderboard Winner!
Cheers Bluebeam Community! In good company here, no doubt about it!
Yeah, @Jes Stafford, well deserved.
Revu 21 ARM 64 Version Test
We're excited to share a unique opportunity to help shape the future of Revu.
We’ve developed a new version of Revu 21, optimized specifically for ARM 64 processors, including Qualcomm’s powerful new Snapdragon X series. As part of our ongoing innovation efforts, we’re launching a limited beta test of Revu 21 ARM 64, and we’re looking for Revu Users with ARM 64 devices to join us.
If you're currently running Revu on any of the following devices, we’d love for you to apply:
- Microsoft Surface Laptop 7th Edition
- Microsoft Surface Pro 11
- Samsung Galaxy Book4 Edge
- DELL Inspiron 14 Plus (Snapdragon X Plus)
- ASUS ProArt PZ13 (Snapdragon X Plus)
- Dell Latitude 7455 (Snapdragon X Plus)
- HP OmniBook X 14 (Snapdragon X Elite)
- Lenovo ThinkPad T14s (Snapdragon X Elite)
- Lenovo Yoga Slim 7x (Snapdragon X Elite)
- Acer Swift 14 AI
- Apple Mac (via Parallels on ARM64)
If selected, you'll receive early access to the Revu 21 ARM 64 test build and be asked to complete a few basic tasks to help us ensure optimal performance on your device.
Interested? Sign up here
If you have any trouble signing up please reach out to me at beta@bluebeam.com
Re: Is there a way? CAD to Bluebeam - Line, Polyline, Polylength
I like where you are going with this, but honestly, this is beyond what our software can currently do.
I have done something similar years back, pulling in Architects .dwg files of buildings and changing elements to suit what I needed for Engineering. It saved so much time.
Sorry, Bluebeam does not have the functionality to pull the Vector information or line (PDF can be Vector or Raster (image)).
