@nexlevel801 Thanks for sharing this tip. Using Alt+0149 for bullet points is an interesting approach (cumbersome, but interesting). How are you handling the indentation for items like 3.1, 3.2, and 3.3?
Re: Already made templates
There is not an option to UNFLATTEN. Neither in the documents tab or shortcut. :-( and when i try to alter the security by changing the permissions, nothing happens when i click on change permissions. …
What is a "nuclear" option?
FeliciaM
One other technique I use, if I can, is to break the file into individual pages.
This also usually fixes the problem without going full nuclear.
This might not be available in a template though.
That's very strange. It's like you don't have the correct permissions, which doesn't make sense. Is this happening to anyone else in your office
You may have to submit a ticket and/or reinstall Bluebeam Revu.
Can Comment replies be made more visible?
I know replies to text box comments are linked and show up in the Markups List. Is there a way to make these replies fully visible in the body of the document next to the comment?
Re: What's your go-to snack to get you through the workday🥪🍎?
Not gonna lie, @James Schmidt - had to look up what that was!!
It seems like the Nuclear option is what you need. This option is what @Luke Shiras posted above.
