Re: 🗓️ March 2025 Challenge - Markup Madness!
I'm almost 4 years into it and still learning.
You can do quite a lot with the UI, but it gets even more powerful when you start to learn the M code
Re: Keep highlighter from switching to text icon
It is funny how that works - so sensitive.
When holding CTRL, and BB still wants to highlight text, Release CTRL and move the mouse out of that part of the sheet, then click it to start the highlight once the icon changes back.
It is a work around, I know. Your highlights will have "tails," but it works when you do not want to auto highlight lines of text.
Re: iPad App Overhaul Desperately Needed
The response from Bluebeam is so disheartening. Cloud based (ie web browser) solutions will hinder the capabilities of mobile markups.
The development team needs to get back on updating the app. It needs to be optimized for current resolutions (including for larger ipad 12.9 / 13 pro) and capabilities.
Re: Tool Chest. Describing for symbols
This is a topic that has been raised many times. It is something that is supposedly coming in a near future update. Looking forward!
Re: FEDRAMP and/or disabling cloud services - CMMC evaluation
February 2025… is Bluebeam working toward CMMC, or are they sticking their heads in the sand, hoping it was just a threat that's going to blow over soon? As a DoD contractor, we are in the process of dropping all software services that aren't FedRamp compliant. It's painful. I hate to lose all the convenience and functionality of Revu studio projects and sessions.
Hoping to do this in a presentation at Unbound 😎
Nice job, @Doug McLean! This is impressive. Way over my head but I know this is a popular topic and I've heard BUG members talk about this before, too!
When our foremen or project managers begin planning the electrical install, they will start with marking up the single-line diagram. I have been helping to make a company standard profile designed specifically for this part of the takeoff, and within it is a tool chest streamlined for the task. The key tool to this operation is a custom grouped markup for identifying the Run ID, Conduit type, Circuit info, and more.
It is composed of a text box, ellipse, and polyline, with the text box as the top element of the group.
The text box is considered the "Run ID", and so by having it as the top of the group the Run ID can be editied by double-clicking the group or by making the change in the comments property in the Properties Panel or in the Markups List.
As you'll see, there is currently no length. To get that property, they will use customized color-coded polylength measurement tools. On the permit drawings, they will place markups to indicate the first means of disconnect for each conduit run, and then draw a proposed path to follow for the install, using the polylength tool appropriate for that run. Then, the tag used in the single-line is copied to the install drawing and the two markups are grouped together. This grouping sequence gives us a markup length (in decimal feet) to begin the initial conduit order. Added length is an estimated amount used to account for the wire needed to terminate the wires. Model length is manually assigned once a true-tape measurement is made in the field. This is what is used for ordering wire harnesses.
Now, we can export the markups to Excel where all these custom columns are put to great use in creating panel schedules, wire orders, and more.
So, that's my humble little conduit tag. The one shown is the EMT tag. PVC, RMC, IMC, FMC, and FNC are color coded for quick identification. These are actually the old look. I'm working on making them easier to see both on screen and printed, while also making the colors more distinct. Here's a quick look at how things are at the moment with the tool chests discussed. This particular setup is for branch conduit drawings, using a slightly different Profile. The feeders discussed above have similar options but the Layer is Feeder Conduit instead.
Did you check out my video above?
Using Power Query turns your markups into a powerhouse.
You got me interested in learning more about Power Query, so I did a search for "Bluebeam Power Query" and your videos with the guys from Morning Coffee Revu popped right up. I'm watching the first one as I'm typing this. Thanks for the info, Doug.
PS - I thought your name seemed familiar. Aren't you pretty active on the MCR webinars? I've been to about a dozen of them, and I think I remember seeing you participating in them.
