Re: What feature/tool could you talk about for hours?
Try using this how-to guide I created for my office. It walks you through all the key steps.
Re: Make Working Between Windows More Efficient
100% agree, Michael. I avoid even attempting it, because it's such a nuisance. Updating it as you suggest would bring huge value to me!
This has bothered me frequently. I often end up with Bluebeam open on one screen and Adobe on the other.
Although I wouldn’t call it a unique use, but I rely on Bluebeam as my main PDF viewer and markup tool. I use it to edit (personal) documents, make notes, and sketch ideas. Lately, I’ve been using it to lay out my home office. Bluebeam works just as well for personal projects as it does for job-related tasks.
Re: ✅ Bluebeam login issues (restored)
Thank you @Marco M. Glad to see that we can finally access this community. Studio is still down for me (has been all day). Any Idea when we should have access to studio again?
Re: Calling all Bluebeam users in Canada!
Hi will the recording of the kick-off meeting be posted soon? I'd like to share it with a few colleagues who weren't able to make it to the meeting
Re: Rotate Page Idea - 45 degree
I like this idea better because it doesn't confuse the print orientation. Although you may want to print sheets in a rotated format so that would require added "white space" to make the new view a rectangular shape.
Hi all,
We recently experienced a technical issue that caused users to have trouble accessing Bluebeam.com domains. The problem has been fixed, but it may take a little while for the fix to fully take effect everywhere due to how internet systems store temporary information.
Thank you for your patience as everything updates. Many users have full service now and most users should see a return to normal shortly. If you're still having trouble, try restarting your device or clearing your browser’s cache.
Clear your local DNS cache For Windows:
- Open the Command Prompt as an administrator. To do this, search for "cmd" in the Start menu, right-click on Command Prompt, and select Run as administrator.
- In the Command Prompt window, type ipconfig /flushdns and press Enter.
- You should see a confirmation message: "Successfully flushed the DNS Resolver Cache."
- Restart your machine.
For macOS:
- Open Terminal. To do this, go to Applications > Utilities > Terminal or search for "Terminal" in Spotlight.
- The command to clear the DNS cache varies slightly depending on your macOS version. Try one of the following:
- For macOS Big Sur and later:
- sudo dscacheutil -flushcache; sudo killall -HUP mDNSResponder
- For macOS Catalina and earlier:
- sudo killall -HUP mDNSResponder
- You'll be prompted to enter your administrator password. Enter it and press Enter.
Marco M
USING CUSTOM STATUSES IN STUDIO SESSIONS.
Not everyone does this and it's literally painful to collaborate in Sessions that don't have Custom Statuses.
I will gladly point people in the right direction if anyone needs help getting started with this. I think the entire industry needs to know about and implement it.
