Re: Calling all Bluebeam users in Canada!
Hi will the recording of the kick-off meeting be posted soon? I'd like to share it with a few colleagues who weren't able to make it to the meeting
Re: Rotate Page Idea - 45 degree
I like this idea better because it doesn't confuse the print orientation. Although you may want to print sheets in a rotated format so that would require added "white space" to make the new view a rectangular shape.
✅ Bluebeam login issues (restored)
Hi all,
We recently experienced a technical issue that caused users to have trouble accessing Bluebeam.com domains. The problem has been fixed, but it may take a little while for the fix to fully take effect everywhere due to how internet systems store temporary information.
Thank you for your patience as everything updates. Many users have full service now and most users should see a return to normal shortly. If you're still having trouble, try restarting your device or clearing your browser’s cache.
Clear your local DNS cache For Windows:
- Open the Command Prompt as an administrator. To do this, search for "cmd" in the Start menu, right-click on Command Prompt, and select Run as administrator.
- In the Command Prompt window, type ipconfig /flushdns and press Enter.
- You should see a confirmation message: "Successfully flushed the DNS Resolver Cache."
- Restart your machine.
For macOS:
- Open Terminal. To do this, go to Applications > Utilities > Terminal or search for "Terminal" in Spotlight.
- The command to clear the DNS cache varies slightly depending on your macOS version. Try one of the following:
- For macOS Big Sur and later:
- sudo dscacheutil -flushcache; sudo killall -HUP mDNSResponder
- For macOS Catalina and earlier:
- sudo killall -HUP mDNSResponder
- You'll be prompted to enter your administrator password. Enter it and press Enter.
Marco M
Re: What feature/tool could you talk about for hours?
USING CUSTOM STATUSES IN STUDIO SESSIONS.
Not everyone does this and it's literally painful to collaborate in Sessions that don't have Custom Statuses.
I will gladly point people in the right direction if anyone needs help getting started with this. I think the entire industry needs to know about and implement it.
Hey George! Here's an updated video on how to modify and organize your tool sets. Hope you find it helpful.
Re: Sign In Button In Revu Is Not Working
There was a bluebeam.com error earlier this morning, but it should be resolved now. Try closing and re-opening Bluebeam. If that doesn't work, try restarting your computer.
Then, if that doesn't work, email support.
We experienced the same issue this morning, but all of our users are back up and running. I hope yours will be, too.
DragDrop registration didnot succeed Revu 21.6
Has anyone experienced this issue after updating to version 21.6?
It doesn’t happen every time, but occasionally I get a popup that prevents Bluebeam from opening. When this occurs, I’m unable to launch the application at all.
Just wondering if anyone else has run into this and found a solution.
Re: Make Working Between Windows More Efficient
I tried that, but you can't move one tab to the other Bluebeam window . . . you still get the floating file. And to try to predict or manage which window a file you open goes to is just another headache . . .way too much effort for what should not be an issue anyway.
I think I'm confused but just in case I'm not, you can open multiple fully tool laden windows of Bluebeam. You just launch Bluebeam a second time. If you're trying to have to separate windows with all the tools of the same file I get the problem.
